Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Apr 2018
    Re: Blackfire paint cleaner. Help!
    What is the car?
    Did you mean 10 year old paint? As in a car from 2008?
    What you typed was an exclamation point followed by a zero --> !0
    I'm starting to wonder if this car has the infamous self-healing paint which is one of the worst paint systems ever invented and put on a car.
    Go to Google and type in,
    self healing paint infinity
    Or type in,
    self healing paint infinity mike Phillips
    And you'll get his results
    Swirls on '08 Infiniti G37s - Self-Healing Paint ?
    Ooops, typo. Car is a 2008 G35. I have read about the "self healing" paint. Somewhere I read that the self healing properties are gone after about 3 years. After that I imagine it would be like regular cc. I did polish with M205 with success when I bought the car in February.
    Quote Originally Posted by sonors View Post
    10 years. typo. I saw some stuff about the "self healing" clear. Not sure if my car has it. I bought it used recently.
    Also it is my understanding that after 3 years or so, the self healing aspect of the clear is gone. I have been able to use M205 with success on this car.
    If you're using M205 without problems then my guess is it's NOT a self-healing paint or you would probably see mico-marring from the M205
    I polished this in February right after I got it. Decided switch to a sealant so I wanted to be sure I had a good surface to apply it to. Figured I'd save clear coat by using a non-abrasive cleaner.
    That's a good though-train, looks like your car's paint simply doesn't like the BF Paint Cleaner. IF the M205 is working, then stick with it and after using it seal the paint. Then wash carefully.
    A Guru on an Infinity G35 discussion forum could probably give you accurate information.
  3. #13
    Super Member JustJesus's Avatar
    Oct 2014
    Orange & LA Counties
    1,294
    That is one reason I'd consider using a paint cleaner, or non-abrasive paint polish myself. The paint on my Jeep is too thin to mess around with!
    Like Mike said above, it could be that self healing paint.
    On a side note, I had a small issue when using this product. On one car, no issues. Next car, a slight hazy film was left behind. Took care of it with some rinseless. More details here -> Review: BLACKFIRE Paint Cleaner
  4. Likes Chopper280 liked this post
  5. #14
    Apr 2018
    What is the car?
    Or type in,
    It's a 2008 black G35. I read somewhere that after 3 years or so the "self healing" (if I have it) properties of the clear would be gone. At that point I would think the clear would be like any other CC.
  6. #15
    Super Member Nix's Avatar
    Jun 2015
    297
    i had same issue with gloss enhancing polish older bottle. hard to buff and would not come off...i have soft honda paint..only thing works for me without an issue is m205 and ultimate polish..also if you are looking for chemical cleaner try P21S Gloss Enhancing Paintwork Cleanser car polish - This pre-wax cleaner and polish is a German blend of quality ingredients that will make wax P21S Gloss Enhancing Paintwork Cleanser
    No issue on soft paint..
    "You can avoid reality, but you cannot avoid the consequences of avoiding reality." - Ayn Ran
  7. #16
    Apr 2018
    Thumbs up on the M205. Took the haze and fog out with no problem and left a finish ready for sealant.
  1. Replies: 14
    Last Post: 11-08-2021, 04:31 PM
  2. Review: BLACKFIRE Paint Cleaner
    By JustJesus in forum Product Reviews
    Last Post: 11-08-2018, 06:44 PM
  3. Have you heard the one about Blackfire Paint Cleaner & 20% off?
    By Elliot@Autogeek in forum Sales & Promotions - For forum members and non-forum members
    Last Post: 08-14-2018, 10:08 AM
  4. Replies: 9
    Last Post: 11-23-2017, 10:59 PM
  5. Blackfire Pad Cleaner, and Microfiber Cleaner Plastic Containers
    By sillybinaries in forum Hot topics & Frequently Asked Questions
    Last Post: 05-28-2013, 08:43 PM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
