Re: Blackfire paint cleaner. Help!
Quote:
Originally Posted by
What is the car?
Did you mean
10 year old paint? As in a car from 2008?
What you typed was an exclamation point followed by a zero -->
!0
I'm starting to wonder if this car has the infamous self-healing paint which is one of the worst paint systems ever invented and put on a car.
Go to Google and type in,
self healing paint infinity
Or type in,
self healing paint infinity mike Phillips
And you'll get his results
Swirls on '08 Infiniti G37s - Self-Healing Paint ?
Ooops, typo. Car is a 2008 G35. I have read about the "self healing" paint. Somewhere I read that the self healing properties are gone after about 3 years. After that I imagine it would be like regular cc. I did polish with M205 with success when I bought the car in February.
sonors
10 years. typo. I saw some stuff about the "self healing" clear. Not sure if my car has it. I bought it used recently.
Also it is my understanding that after 3 years or so, the self healing aspect of the clear is gone. I have been able to use M205 with success on this car.
If you're using M205 without problems then my guess is it's NOT a self-healing paint or you would probably see mico-marring from the M205
sonors
I polished this in February right after I got it. Decided switch to a sealant so I wanted to be sure I had a good surface to apply it to. Figured I'd save clear coat by using a non-abrasive cleaner.
That's a good though-train, looks like your car's paint simply doesn't like the BF Paint Cleaner. IF the M205 is working, then stick with it and after using it seal the paint. Then wash carefully.
sonors
A Guru on an Infinity G35 discussion forum could probably give you accurate information.
sonors
That is one reason I'd consider using a paint cleaner, or non-abrasive paint polish myself. The paint on my Jeep is too thin to mess around with!
Like Mike said above, it could be that self healing paint.
On a side note, I had a small issue when using this product. On one car, no issues. Next car, a slight hazy film was left behind. Took care of it with some rinseless. More details here -> Review: BLACKFIRE Paint Cleaner
What is the car?
Did you mean
!0
Or type in,
It's a 2008 black G35. I read somewhere that after 3 years or so the "self healing" (if I have it) properties of the clear would be gone. At that point I would think the clear would be like any other CC.
i had same issue with gloss enhancing polish older bottle. hard to buff and would not come off...i have soft honda paint..only thing works for me without an issue is m205 and ultimate polish..also if you are looking for chemical cleaner try P21S Gloss Enhancing Paintwork Cleanser car polish - This pre-wax cleaner and polish is a German blend of quality ingredients that will make wax P21S Gloss Enhancing Paintwork Cleanser
No issue on soft paint..
Thumbs up on the M205. Took the haze and fog out with no problem and left a finish ready for sealant.
