Results 11 to 20 of 21
    Junior Member CheckeredFlag's Avatar
    Aug 2012
    Haslett, MI
    47
    Re: How to Finish Garage Walls
    how about a splatter / textured finish ?
    "Good Luck on your project"
    Aug 2010
    New Jersey
    15,159
    Quote Originally Posted by CheckeredFlag View Post
    As I was alluding to, garages tend to get dusty, and textured walls hold that dust and are difficult to clean.
  3. #13
    Super Member RedXray's Avatar
    Oct 2012
    The Detail Bay, USA
    850
    Prime the walls first then use a satin gloss latex waterbased paint. If you have a large wall area, consider buying an 18" roller, frame and pan.
    Second Best One Legged Detailer in The World... That top slot is unattainable
  4. #14
    May 2012
    Erie, PA
    192
    Do you mean you just finished hanging all the drywall or you finished plastering the seems and filling in all the screw holes?
    We are the music makers....and we are the dreamers of dreams.
  5. #15
    Aug 2010
    Fairmont, MN
    3,189
    You're talking about a plaster skim-coat? Like you would do inside an expensive house so the walls look smooth with no sheetrock joints or nail/screw heads showing? No one does that in a garage AFAIK. Or are you talking about a stucco finish? I have that in mine and I hate it because you can't keep it clean.
    As others have said, just use an exterior grade semi-gloss paint and you should be good to go. You might want to put a "chair rail" around the wall if you think you're going to be hitting it with car doors or tool boxes or detailing carts.
    Plus, if you bump in to it, road rash (wall rash?) is the word of the day. It can remove skin in a heartbeat.
    Bill
  6. #16
    Super Member Mike Moore's Avatar
    Dec 2009
    Sunny South Florida
    967
    Are you talking about finishing the drywall with tape and mud so you can paint it and achieve drywall "orange peel"?
    On the stucco as others have said just paint it with exterior semi-gloss and you're done.
  7. #17
    May 2013
  8. #18
    Super Member Pureshine's Avatar
    Dec 2012
    Seattle
    4,774
    Quote Originally Posted by WAXOFF View Post
    Pureshine. Are you a VW owner?
    Yes I am since I was 16
  9. #19
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Why not get something like "melamine resin coated paneling" to cover-up the unfinished drywall:
    Shop DPI 1/8-in x 4-ft x 8-ft White/Gloss Hardboard Wall Panel at Lowes.com
  10. #20
    Sep 2013
    35
    When I had my house built - I had them use plywood for the garage walls. Best decision i ever made in there. I can hang things where ever i want and dont have to worry about finding studs. I taped and plastered the seams and finished it w/ a white semi-gloss.
    I just wish I would have done the floors w/ epoxy or something before we moved it.
  1. Replies: 1
    Last Post: 12-10-2017, 07:11 PM
  2. Garage Help - Floors? - Walls? Ideas?
    By BrianMcLeod in forum Off-Topic
    Last Post: 05-11-2015, 09:54 PM
  3. White paint on walls in garage
    By wrb_subie in forum Auto and Garage Accessories
    Last Post: 03-13-2015, 10:44 AM
  4. Adding some color to the garage walls.....
    By dpscoupe in forum Off-Topic
    Last Post: 06-20-2013, 06:29 AM
  5. Garage Walls
    By gohandbz8 in forum Auto and Garage Accessories
    Last Post: 12-30-2007, 01:02 AM
