Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Subwoofer?
    Super Member Nuke33's Avatar
    Sep 2006
    New York
    1,606
    I think its a 350 watt 2 channal i cant remember ill look at it when i got home next week, i was thinking like a sony 10''
    Super Member wytstang's Avatar
    Apr 2006
    Summerville,SC
    4,216
    I recently started to get back into beefing my audio and have done lots of research on car audio forums. And there are plenty of affordable subs out there that will give you an awesome bang for the buck. What comes to mind are TC-1000 from TC sound they are great specs and from the crap load of threads I've read they have a strong following. And they sell them direct with free shipping to boot. Check out car audio forums 'dot' com and search TC-1000. They only thing stopping me from buying one 12'' is they don't offer a dual 2 ohm speaker that I need to run my 1 ohm stable amp. Since I only want one strong sub I had to chose Oz Audio which cost a bit more but man they are awesome subs. Good luck and car audio forum and a lot of info to offer just search the forums.
  3. #13
    Apr 2007
    I'd get a single 12 and be done with it, I had a single 12 in my integra, JL 12W6 it hit hard and got low in a fairly small box. In my current car I was limited to a 10" and while it can hit it really doens't have the extension of my 12...I miss that low extension
    You also never stated what your budget is, some people are telling you to get a new headunit, but if I was on a limited budget and had to do it in pieces I would add the sub and amp, via the cleansweep or some other line output device to the stoc CD unit and then get a new head unit later.
  4. #14
    Super Member StephenK's Avatar
    Jul 2006
    Rochelle, Illinois
    1,589
    10" will hit harder than 12". all you lose by dropping down to a 10 from a 12 is a little bit of power handling
  5. #15
    Super Member Excessive Detail's Avatar
    Apr 2006
    1,166
    Quote Originally Posted by Nuke33
    I was thinking about putting a sub woofer into my 2000 Honda Civic, Is this a DIY project and what would i need i have an amp... Do i need a new Cd player I olny have a stock one.
    Thanks,
    Ryan
    You can add subs without adding an aftermarket cd player by using line converters, which basically convert speaker wire coming form your stock radio into rca connections, from there you can hook up rca and run to your amp. Yes, this is not as good as using an aftermarket radio, most people wouldn't know the difference, I do this to cars on a regular basis, now that a lot of newer cars are becoming harder and harder add radios and speakers. The converter only cost about $15, and you can hook more than one, I had three in my car before I got a aftermarket radio. They are really simple to hook up. This is what they look like.
    Buy the Metra Line Output Converter (ALOC648) and other Car Amplifier Audio RCA Cables at circuitcity.com
    This one is little more expensive because its made for four channel amps, which you wouldn't need for a sub.
    Hooking it up in your car is really simple, the converter has five or six wires coming out of it, depending on brand. Four wires are for speaker connection, usually white and white/black and grey and grey/black, positive and negative basically for two speakers. All you would have to do is catch the two rear deck speakers, which can be accessed through the truck, white wires on one speaker and grey on the other. The other two wires, which are usually brown are used to ground out the converter to prevent excees noise, I rarely use them, hardly ever seen noise come from a converter.
    All in all this is a pretty good way to go and cheaper than buying an aftermarket radio.
    What subs and amp were thinking of going with?
  6. #16
    Apr 2006
    1,166
    I'm taking this time to show off my setup, by far in my opinion the best brand on the market, a little expensive, but well worth it in the long run, sound quality is amazing in both my sub and highs. I hit a 134 db on the dash with just that one sub. If you hae the money give any JL Audio Product a try.
    My highs are all Boston Aocustics SL Seperates 5x7s, another great brand, amazing sound quality and fairly priced. The sub is a 12" JL W7, Amps are JL 300/4 and 500/1
    Not the greates install, but I wanted to keep it simple and not affect the car in any way so when I sell it or trade it in its like it was when it was new. My next project is a 7" lcd screen in my front grill, yes, front grill, also I'm gonna try and put some 3.5" screens in my headlights. Definitley posting pics when that happens.
  7. #17
    Apr 2007
    49
    A metra converter works fine if not abused for low signals. There are plenty of people who use (i am planning to) these converters and get a decent signal out of them. You can tap into the rear speaker signals usually and get a decent sound from a sub. One recommendation, get a 12" if single, a lot more cone area equals a lot more air moved and a decent sound, plus it goes lower.
    Budget dictates everything here, you could get the sub and amp with a converter and then convert to a better head unit later if necessary. You could also swap out your factory speakers before and see an improvement in sound quality.
    Plenty of sites out there for car audio. Buy a decent sub that fits within your budget as well as a decent amp and you are good to go.
    Big thing with a converter is not not abues it and send a higher signal than needed to the amp which usually results in distortion. Simple explanation for something that is more complex than a simple paragraph.
    2001 Mustang Cobra Vert, Lazer red clearcoat,weekend toy
    2001 Infiniti QX4, pearl white two tone
    PC 7424 with XMT products and CCS pads
  8. #18
    Apr 2006
    1,166
    There are also converters that will boost rca voltage to that of aftermarket units, JL makes one called the Clean Sweep, expensive, but for those with cars that they haven't made radio kits for or thse higher end systems with optical audio connections, this is the way to go. They do make some cheep converters with adjustable gains, which will aid in sound quality an power.
  9. #19
    Apr 2007
    Quote Originally Posted by detailgod
    No way my current 10 hits harder than my previous 12, power is the same if not more to the 10. I had the SPL and the SQ with the 12, just got to pick the right one. As I said if I had the room for the 12 I would of put one in without thinking twice.
  1. not really car detailling..but subwoofer detailing
    By krouchchocolate in forum Auto Detailing 101
    Last Post: 11-23-2006, 12:14 AM
