Re: Loss of pressure with my new pressure washer hose
Just out of curiosity, was there anything wrong with the machine other than the annoyance factor with the Simpson hose?
Originally Posted by spewking
Lee, what hoses are you looking to buy? I may join you in the purchase as I too have the Simpson 50' 5/16" with the sunjoe. I want to stay with the 50' length to stretch around the car without having to move the washer. Thanks.
I will say that if you didn't know any difference and your machine is working well with the hose, then I'd stick with it. I probably would never have known had I used this hose from the very start. After all, I would not have had anything to compare it to.
I will likely get a 30' 1/4" from Lowes. Blue Hawk 30" 1/4" diameter. It looks and feels exactly the same as the Simpson 50' that you and I have.
If I were to buy a 50' 1/4", I know this one is available, as mentioned by another poster in the other thread. It has been said that this is the same as the Flexzilla. Apache 50' 1/4" diameter Engineered Hybrid Polymer
I'm not sure I really need 50'. Also, I don't really like the bend restrictors on the Apache as they look cheap. The bend restrictors on the Simpson and Blue Hawk look much nicer.
Nope. It used to have a funky cycling issue with the motor, but that went away. That could've been a water pressure issue. I'm still using the Greenworks 1500psi unit I purchased from Lowes over 2 years ago.
Damn, I just bought a 5/16 hose from Amazon for $33 and was going to use it this weekend. Now time for me to return it.
Originally Posted by CaveRacing
So get this - In this thread, we discussed a longer hose for the SunJoe SPX3000. I gave my opinion of a hose I recently bought, the Simpson 50' 5/16" (inside) diameter hose. It's a great hose. It doesn't kink, it isn't heavy, and it got great reviews. Some others here have even purchased it on my recommendation.
Well... when I first connected it to my Greenworks 1500psi PW, I noticed that the motor would run for just a second or two longer when the machine was powered on or when releasing the trigger. Also, when I pulled the trigger, it would take juuuust a second or so longer for the spray to flow. What was different? Before, whenever I released the trigger, the motor would immediately stop. When I pulled the trigger, it would immediately spray. Oh, the old hose was a 1/4" diameter 30' thermoplastic Briggs & Stratton branded hose. I don't much care for the thermoplastic. It is hard, gets brittle, yada yada yada. It was just like the cheap hose that comes with all of these machines, only longer. Hence, the new hose.
Ok, so my PW was having some funky issues anyway, so I didn't think much about these changes when I installed and used the new hose. Today, however, I decided to connect the old hose to see what would happen. Yep, it made it a difference. The reaction of the motor when I pull/release the trigger is much quicker AND the pressure was drastically improved! My little Greenworks machine is back to normal!
I know that the length of the hose can make a difference in pressure, but the difference in 30' and 50' is minimal when it comes to pressure loss. I mean, we're talking about a few PSI... nothing to really notice. The difference, however, is in the diameter of the hose. Apparently, going from 1/4" to 5/16" inside diameter DOES make significant difference in the performance of the pressure washer. BAH!!
I read some postings where people suggested upping the inside diameter if you're going to extend the length. So that's what I did with this Simpson hose. NOOOOO! And today, as I was reverting back to the old hose, it dawned on me that pressure increases as the diameter decreases. So what I effectively did with the new hose was decrease pressure by enlarging the inside diameter AND by lengthening the hose (albeit a negligible difference, I'm sure).
Since I like the material of the Simpson 5/16" hose, I found a 1/4" version at Lowes. At least, it looks and feels exactly the same, has the same "Morflex technology," but is branded BlueHawk. That's for Lowes. So I'll likely get this one. There aren't many 50' 1/4" QUALITY hoses to choose from, so this is probably the best bet.
So for anyone that is using a similar pressure washer (electric, cold water, 1500-2000psi), I'd suggest sticking with a 1/4" hose to maintain optimum performance.
Anyone need a virtually new Simpson 50' 5/16" diameter pressure washer hose?
Thanks for reading!
I also noticed you said that you connected it to your Greenworks and you had issues. What about the Sun Joe?
The SunJoe gave me issues, so I took it back. Even with using the proper metal adapter, it still leaked. I tried Teflon tape, pipe dope, and both together. Leaked. I didn't feel like messing with it. I never had to screw around with the Greenworks or the Ryobi, so back to the store it went.
So I got to use the Sun Joe...and I'm loving it! Washed 3 cars. I got a quick connect for the garden hose to the washer. At first, it was gushing like a mofo with the teflon. I guess because it wasn't fully on, water was coming out. Removed the teflon and tightened the quick connect and no more leaks.
I purchased the Apache 50' 1/4 diameter - http://amzn.to/1HVieWa
It was scheduled for Sunday delivery and was hoping it would arrive and on time. Just when I was about to hook up the SJ 20', mailman came through and delivered the new hose. Hooked it up and it worked without a problem. The Home Depot quick connects fit perfectly, no leaks and offered enough pressure to wash cars.
Awesome!!
I picked up a new Greenworks 1600psi for $70. I getting the 30' blue hawk 1/4" hose tomorrow.
1/4" is the way to go!
How do you like the Apache hose?
Awesome!!
Not as thick as the one that came with the washer. But 50' is long enough for what I need to do...maybe a little too long.
What made you decide to go with blue hawk?
I may give the 30' blue hawk a try. They don't have at any of the local Lowes store so I have to get it shipped. If I end liking the blue hawk, I'll return the Amazon one. Gotta love free returns.
Ended up ordering the 30' Blue Hawk for pick up at Lowes. They did have the 30' but picture are different, price and info is the same except for the PSI (2700 vs 3100)
This is the one listed with 1/4 - Shop Blue Hawk 1/4-in x 30-ft Pressure Washer Hose at Lowes.com
This is the one I ordered - Shop Blue Hawk 30-ft Pressure Washer Hose at Lowes.com
Oh wow. Frankly, I didn't even realize there were two different ones. My local Lowes had the 3100psi in stock. I bought online and just picked it up, actually.
I like the blue hawk because it looks and feels exactly like the Simpson, only with the proper specifications. While it is only 30', I really don't think I have a need for 50'. I'd be willing to bet it is made by Simpson (or by whoever makes the Simpson. It has a nice feel, is light, and also has quality bend restrictors. Overall, it should be quality hose.
By Coatingsarecrack in forum Auto Detailing Tools and Accessories
Last Post: 04-06-2019, 01:00 PM
By Daviddear30 in forum Auto Detailing 101
Last Post: 08-11-2017, 12:57 AM
By Wiserphil in forum Ask your detailing questions!
Last Post: 02-21-2017, 09:24 PM
By cc rider in forum Auto Detailing 101
Last Post: 11-09-2014, 08:40 PM
By Ipsdrew in forum Products Guides
Last Post: 02-07-2014, 04:09 PM
