Re: SunJoe SPX3000 longer hose?
So you're using it to dial back pressure some how to safely clean with higher powered machines. Given a low enough pressure at the wand handle, I suppose you could ball park a more safe PSI to wash at. Not a bad idea
Yes, you can dial back the PSI using the uploader (black knob on second pic w/ a rubberband around it). Again, i rarely use it because i usually soft wash houses using much bigger nozzle orifice, hence the PSI coming out is very low but lots of water shooting out
Originally Posted by spewking
Lee,
Thanks for the help. I'll post pics when I get it together.
Purchased a sunjoe3000 (from Walmart with 3 years of extra protection for $18), a Simpson 50' hose, brass fittings for water supply, and the wand/quick connect/short pipe supplies from northern tool. I am looking forward to the short wand set up that will be great for foam cannon and its ease of use.
Thanks for sharing your set up. I definitely benefitted from your previous experience -- it made it easy. Can't wait!
David
David, did you get it all up and running?
My SPX3000 just arrived. Our setups are likely exactly the same!
Not yet. The Memorial Day price was cut everywhere by sun joe so I took my receipt and unit back to Walmart and got it for the $153 sale price. All my connectors and quick connects came in from northern tool, so I'll get it all ready this week. I'll post pics when it comes together!!!
Thanks again.
David
Thanks again.
David
Awesome. I should have all of mine up and running this weekend. Oh, be sure to wrap some Teflon tape on the little brass pipe that is your short wand. I think you can see it in my photos. You shouldn't have to manhandle it since it is pipe thread, but Teflon tape helps it tighten more easily so you should get leak-free connections.
Those that want a flexzilla but cant find it will be pleased with this hose. Its the same thing but in blue....I own both so Im not talking out my butt.
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
Originally Posted by fotomatt1
So I bought a whole set of M22 - 3/8" Quick Disconnect adapters at Home Depot, however the Female M22 end is too small to fit the Male M22 end on the SunJoe hose. Are there varying sizes of M22 connectors?? I thought an M22 was an M22?
First time poster and I just recently purchased a Sun Joe SPX3000 from Walmart for $159 and got cashback which made the deal even better. Bought a foam gun (MTM Hydro) from dipyourcar.com along with soap and quick connect adapters for the garden hose.
I also bought a whole set of M22 Quick Connect adapters from Home Depot. It wouldn't fit.
On the female end of the hose, the inner circle was wider than the opening on the HD adapters. I ordered a used/returned Amazon.com: Apache 10085591 Thermoplastic Rubber Black Pressure Washer Hose, M22 Female x M22 Female Connection, 3700 PSI Maximum Pressure, 50' Length, 5/16" ID: Industrial & Scientific for $33 from Amazon. Hopefully it will fit the adapters. I've saw some of the links that was posted but some had a 1/4 diameter for the hose which would result in less water. 5/16 is the closest I saw to the 3/8 diameter hose.
Now I have to find a nice weekend to wash my car.
Originally Posted by iazybandit
Received the hose and the Home Depot quick connects were a perfect fit. Going to give it a try over the weekend.
I ended up returning the hose due to possible loss of pressure - http://www.autogeekonline.net/forum/...sher-hose.html
I returned it and ended up getting Apache 50' 1/4 diameter hose - Apache 10085585 Engineered Hybrid Polymer Xtreme Flex Pressure Washer Hose, Female Metric Connection, 3100 psi Maximum Pressure, 50' Length, 1/4" ID: Amazon.com: Industrial & Scientific
Washed 3 cars with it. Worked well but probably a bit too long for my needs. Fairly light in weight, fit the Home Depot quick connects. Even after straightening the hose (to the best that I could) and uncoiling it, it seem like it still coiled a little. I never used the SJ 20' hose that came with it so I can't compare if there was a loss in pressure but it worked well for washing cars.
I also ordered a 30' hose from Lowes per suggestion of CaveRacing - Shop Blue Hawk 30-ft Pressure Washer Hose at Lowes.com
It's only 10' more than SJ, diameter is 1/4 which is the same as SJ. Going to give it a try the next time I wash the car or pressure wash my PVC fence
By Colehep in forum Off-Topic
Last Post: 07-19-2018, 03:45 AM
By Dtcjem in forum Auto Detailing 101
Last Post: 03-13-2017, 01:15 AM
By fotomatt1 in forum Auto Detailing Tools and Accessories
Last Post: 06-01-2015, 10:52 AM
By Lexi65 in forum Auto Detailing 101
Last Post: 10-13-2013, 06:24 PM
By alko in forum Off-Topic
Last Post: 04-24-2012, 06:29 PM
