Re: SunJoe SPX3000 longer hose?
Originally Posted by fotomatt1
So I bought a whole set of M22 - 3/8" Quick Disconnect adapters at Home Depot, however the Female M22 end is too small to fit the Male M22 end on the SunJoe hose. Are there varying sizes of M22 connectors?? I thought an M22 was an M22?
Yep this is exactly what I found out yesterday when trying to test the pressure using a gauge. The hose fittings and subsequent washer/lance fittings are bigger than the standard m22 fittings.
I had to swap my entire hose over but had a leak near the lance. You may need a new lance along with a hose. By the time you incur all those costs the value is negated.
Anywhere to buy the Simpson hose in a store? I'd love to pick one up today if possible.
Lowes sells their Blue Hawk branded hose, which I believe is the same as the Simpson. It looks and feels the same and has the same MorFlex technology. The downside is that it is 40' instead of 50'. But, it is available in store, albeit slightly more expensive.
Shop Blue Hawk 5/16-in x 40-ft Pressure Washer Hose at Lowes.com
This is my set up.
Closer look
Nice! Our trigger setup is very similar! And I love the hose reel. This is the one thing I'm missing...storage for the pw hose. Is that a 50' hose or is it longer? Also, do you have another hose coming out of the reel to connect it to the SunJoe, or do you unwind the whole thing and remove it from the reel to use it?
Originally Posted by snellvilleauto
This is my set up.
Closer look
Your pics aren't showing up.
It's the 50' 3/8 Northerntool hose. Yes, I unwind the whole thing. The reel is just for storage.
That's weird, CaveRacing and I have no problem seeing the pictures.
Strange...I couldn't see them on my phone through Tapatalk or the AGO app, but when I got to work I could see them on my desktop just fine. Bizarre.
Tractor Supply.
Whats the point of the pressure gauge?
Just curious as rated PSI for most machines is measured at the tip of the nozzles. Meaning, if you put the tip of the nozzle right on the surface to be cleaned, you'd get XXXX PSI of pressure.
Compression is still happening in the lance and tip (at least if the tip has a smaller diameter orifice than the wand). Measurements at the hose connection port are somewhat inconsequential as the fitting diameter, hose diameter, wand diameter and taper and the selected nozzle can all still affect the final PSI rating.
By Colehep in forum Off-Topic
Last Post: 07-19-2018, 03:45 AM
By Dtcjem in forum Auto Detailing 101
Last Post: 03-13-2017, 01:15 AM
By fotomatt1 in forum Auto Detailing Tools and Accessories
Last Post: 06-01-2015, 10:52 AM
By Lexi65 in forum Auto Detailing 101
Last Post: 10-13-2013, 06:24 PM
By alko in forum Off-Topic
Last Post: 04-24-2012, 06:29 PM
