Page 12 of 22 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 111 to 120 of 213
  1. #111
    May 2017
    72
    Re: SunJoe SPX3000 longer hose?
    you can try contacting Damien Johnson in the UK, he runs "Q Washers" services in the UK, hes the king of anything pressure washers as far as fittings, custom setups, hoses, etc... Ive bought from him in the past back when i had a Karcher pw. His email: qservices1@live.co.uk He usually responds within a day or two. Just be very specific on what your looking for and he may be able to help.
    To me the stock hose end for the spx3001 looks very similar to the Karcher K-series hose end fitting, see pics below. There is a notch on the Karcher fitting which may effect the seal when the hose is plugged into the SunJoe hose reel receptacle... i just don't know. We would need a guinea pig to try it out.
    *EDIT* I just did a quick search through Damien's listings and found this...
    KARCHER K SERIES HOSE 20M SCREW FITTING 22MM FEMALE X MALE GUN Q RELEASE PROBE | eBay
    Attached Thumbnails Attached Thumbnails SunJoe SPX3000 longer hose?-untitled45-jpg   SunJoe SPX3000 longer hose?-untitled44-jpg
  2. #112
    Feb 2016
    Quote Originally Posted by ShinyGC View Post
    That’s exactly what I’m looking for...I want to use that in a 50ft hose so that I can just plug it into the spx3001 reel! Anyway to get a part number for that?!
  3. #113
    Feb 2016
    I ordered it. Found it on Aliexpress of all places..should be here in 10 days or so...I’ll report back on the fitment on it when it comes in to see if it’s a viable option for those of us w the funky reel attachment SunJoe SPX3000 longer hose?
  4. Thanks BudgetPlan1 thanked for this post
  5. #114
    May 2017
    72
    Quote Originally Posted by CaptN D View Post
    post a link to the one you bought, i’m curious.
    I just searched on there and found several hoses with potential:
    Online Shop 10M Car washer hose with K5 connector 400Bar 5800PSI, M22*1.5 *14mm ,high pressure washer hose | Aliexpress Mobile
    Online Shop 6m & 10m x 220bar High Pressure Washer Car Washer Rubber Hose for Lavor Lavorwash High Pressure Cleaners | Aliexpress Mobile
    Online Shop 6m/ 10m x 160bar High Pressure Washer Car Washer Hose for Nilfisk & STIHL (We are not STIHL, but offer compatible parts) | Aliexpress Mobile
    Online Shop 2017 Direct Selling Top Fashion Gs High Pressure Washer Hose 5 Meters Quick Connect With Car Gun(moch001) | Aliexpress Mobile
  6. Thanks Karura thanked for this post
  7. #115
    Sep 2012
    Hopefully we can confirm that the Karcher style head would fit into the SPX3001/4001.
  8. #116
    Super Member ski2's Avatar
    Dec 2011
    Southwest PA
    1,826
    For those of you with the SPX 3000--Is there any reason to not just use the Sun Joe 25' extension high pressure hose??
    Amazon.com : Sun Joe SPX-25H 25' Universal Pressure Washer Extension Hose for SPX Series and Others : Garden & Outdoor
    If there is some reason to not use the extension--would this hose work with the 3000?
    Amazon.com: UBERFLEX Kink Resistant Pressure Washer Hose 1/4" x 50' 3,100 PSI with (2) 22MM: Garden & Outdoor
  9. #117
    Super Member BudgetPlan1's Avatar
    Dec 2015
    Central OH
    1,999
    Quote Originally Posted by ski2 View Post
    I use the SunJoe extension hose with the 25' hose that came with 3001, which is essentially the 3000 with a hose reel.
    The other hose won't work if you wanna attach it directly to the 3000 to replace stock hose. Hose to pressure washer connection on sunjoe is some wonky, Karcher-ish proprietary connection.
    Also the SunJoe extension hose will fit SunJoe gun but not other 'standard' accessories without MTM 15mm to 14mm fitting because SunJoe fittings are a European-ish 15mm (or 14mm...i can't remember which).
  10. #118
    Dec 2011
    Southwest PA
    1,826
    Thanks BudgetPlan1 !!! How is the stock SunJoe hose and extension hose as far as flexibility and lack of kinking??
  11. #119
    Dec 2015
    Central OH
    1,999
    Not too bad. Have an MTM swivel on gun end so that helps.
  12. Thanks ski2 thanked for this post
  13. #120
    May 2017
    72
    its a very stiff hose with non standard fittings... In my opinion id buy a new hose all together and just adapt it to the PW.
    I got mine from Kleenrite online (50' single wire rubber hose) and bought an m22/15mm to m22/14mm adapter for the back of the unit. Done.
  1. What's wrong with my Sunjoe spx3000
    By Colehep in forum Off-Topic
    Last Post: 07-19-2018, 03:45 AM
  2. SunJoe SPX3000
    By Dtcjem in forum Auto Detailing 101
    Last Post: 03-13-2017, 01:15 AM
  3. SunJoe SPX3000
    By fotomatt1 in forum Auto Detailing Tools and Accessories
    Last Post: 06-01-2015, 10:52 AM
  4. Replies: 13
    Last Post: 10-13-2013, 06:24 PM
  5. Longer Pressure Washer Hose...
    By alko in forum Off-Topic
    Last Post: 04-24-2012, 06:29 PM
