Took it out for its maiden voyage today
- I bought a deck brush - and cleaned the deck!!
Also tried out the Foam Gun on the car
Discovered a few things:
#1 - The hose I bought wrapped itself up in knots more often than expected... But it was only 60 Deg. - so it may get better with some heat.
#2 - I had a set of Quick connects left over from my former Karcher PW - they fit and actually worked well on the gun side - so no M22 to 3/8" conversion used there.
#3 - Dry the car next time - I was busy with the deck for most of the afternoon - and car wash was a late trial - typically I use the Backpack Blower to dry the car - and did not - and noticed water spots everywhere....
So for the first use - it was successful - a few things to work out - but so far so good!
I'll probably get the same Quick Connects I had on the Karcher - and just use those - makes a cleaner setup - but have the M22 convertors if needed. Still debating gun - stock was not too bad - so I'll try it few more times before deciding.
