hydrotech pad guide
Hi, I'm using optimum "hyper" products with hydrotech pads. The car I'm working on is an 01 Benz with rock hard silver metalic paint.
I got her shined up pretty good last year, it took hyper compound and a hydrotech cyan pad just to see any noticeable paint correction.
I'm wondering, for giving it a touch up will G-P-S with a tangerine pad finish down LSP ready? Do I need to use my red pads at all?
will this combo provide any noticeable defect removal?
Im realistic, she is my dally driver, so it probably won't be perfect, but shiny is good!
Re: hydrotech pad guide
I think tangerine and GPS would make a pretty good combo in your situation. It should give you some very light cleanup, where the crimson probably won't. Or just use some Hyper Polish? Hyper Polish + tangerine should finish fine on hard silver IMO. Crimson never seems to do much for me on hard paint, even though it's supposed to have more cut than a traditional finishing pad.
Thanks!
think I should go PC or rotary?
All of my pads are 4" if it matters.
I liked the hydrotechs until I tried hybrids.
What are those and what is it that they do better?
They last much longer than the hydros is one major difference. http://www.autogeekmobile.net/hybrid...nish-pads.html. You don't have just three choices, a wider array of foam to get a better finish!
I like only three choices! It keeps my OCD in check
Hydroshred pads: amazing finishing combined with the durability of wet facial tissue.
A tangerine pad with GPS should finish down very well on hard silver paint, but you're not going to get a ton of correction.
Same here! I added LC Ultrafiber microfiber pads to get some extra weight in the correction department - If needed. I absolutely love these pads. I'll know in the next week or so If they'll be able to hold up. So far they really perform great. The Cyan and FG 400 did a total clean up on a car that has only ever seen tunnel washes. Tool was a Porter Cable 7424XP, on speed 4.5.
How do the microfiber pads work finish and durability wise? Is it worth switching?
Specifically the ones from Optimum, I just really like that company I guess.
By Scoobertin in forum Auto Detailing Tools and Accessories
Last Post: 07-18-2016, 03:46 PM
By swanicyouth in forum Wool & Foam Buffing Pads
Last Post: 04-07-2013, 10:40 AM
By Bigbull2984 in forum Wool & Foam Buffing Pads
Last Post: 06-02-2012, 04:15 PM
By WRXINXS in forum Wool & Foam Buffing Pads
Last Post: 04-19-2012, 06:23 PM
By superwhite in forum Wool & Foam Buffing Pads
Last Post: 03-21-2011, 11:48 AM
