Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Super Member CDot's Avatar
    Aug 2013
    1,010
    Re: Harbor Freight Polisher
    Quote Originally Posted by merlin View Post
    I'm a big fan of the Speedy Prep Sponge or towel (FINE) grade.
    I use Iron-X (Lemon Scent) then a Nanoskin Speedy Prep.
    I rarely use a clay bar any more.
    Used Iron-X Lemon for the first time earlier this summer...I think claying with the SpeedyPrep Fine Sponge literally took 5 min, if that. Iron-X makes a huge difference.
    2011 Toyota Camry SE - Magnetic Gray Metallic
  2. #22
    Super Member Azure's Avatar
    May 2013
    Indianapolis, IN
    400
    Does anybody have a speed selection to respective RPM conversion for the Harbor Freight variable DA buffer?
  3. #23
    Aug 2013
    St Louis metro (Illinois)
    5,809
    I don't know if there are any RPM conversions out there, but I typically use the same recommended speeds people recommend for Porter Cable units. Those machines seem to have a 1-6 speed scale as well, and by using the same speeds I've been very successful so far.
  4. #24
    May 2013
    Indianapolis, IN
    400
    I purchased a Meguiars DA microfiber correction system kit and it mentioned setting RPM. I was guessing when I used it lol. I looked at the RPM range HF listed in their instructions and kinda guess what number would achieve a given RPM. It would be nice to know for sure. Could I use an RPM scope to find out? I could make a mark on my pad, like many do to tell if the pad is spinning. Does that seem logical?
  5. #25
    Aug 2013
    5,809
    Quote Originally Posted by Azure View Post
    You might be over complicating things here. I don't use the MF pads, but there may be some discussions on this board where members have discussed what settings they used for the DA's and just go with that rather than getting too wrapped trying to calculate RPM.
    Looking at the HF, the Porter Cable, and the Meguiars DA's, I don't see any of them with an RPM scale like a rotary polisher. They all seem to have a simple 1-5 or 1-6 scale.
  6. #26
    May 2013
    Indianapolis, IN
    400
    That's what was so confusing. I've seen so many "set your DA to # blah" for this and the kit was talking RPM lol.
  7. #27
    May 2013
    Indianapolis, IN
    400
    I’m sure this is known by many, but it surprised me. I used a 4” pad setup on my Harbor Freight polisher and it does much better with the smaller, lighter pads. I used Adam’s Polishes pads and a backing plate. The 6” pads I was using didn’t allow for much pressure at all before it would lose its spin motion. I might pickup a 5” set from somebody and see how they perform with it on my wife’s Envoy.
    IG: @ab_mach1
  8. #28
    Super Member DaveT435's Avatar
    Jun 2012
    Arlington Texas
    3,982
    IG: @ab_mach1
    5" is definitely the way to go on that machine. The thin pads tend to work better also.
    2015 F-150 Crew Cab Lariat
    2016 Chevrolet Camaro 2SS
  9. Likes KBsToy, Azure liked this post
  1. Harbor Freight DA polisher N/A. Alternatives?
    By SoreArms in forum Auto Detailing 101
    Last Post: 05-28-2019, 08:53 PM
  2. Harbor Freight DA 6" Polisher
    By yamaharider529 in forum Auto Detailing Tools and Accessories
    Last Post: 09-29-2017, 02:27 AM
  3. Harbor Freight polisher question
    By Supergus1 in forum Ask your detailing questions!
    Last Post: 12-04-2014, 08:04 PM
  4. Harbor freight 6'' da polisher pad question
    By jstevens66 in forum Auto Detailing Tools and Accessories
    Last Post: 05-09-2014, 03:39 PM
  5. Harbor Freight DA Polisher - New
    By Viper6 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 11-30-2013, 11:03 PM
