Results 1 to 3 of 3
    Jul 2020
    56
    Electric Pressure washer GFI Plug dead
    I have a Royobi electric pressure washer for 2 years, it looks like the GFI plug is dead. Does anyone make a replacement unit I can pop on there or are they so amp/watt specific that a generic GFI plug wouldn't work with my unit?
    May 2013
    TN
    1,768
    Re: Electric Pressure washer GFI Plug dead
    You need to size it to the number of amps, which would either be 15 or 20 amps but I doubt there is much of a price difference so I would just get a replacement GFCI plug for 20 amps but make sure it is a standard plug. A true 20 amp plug has one of the 2 prongs turned 90 degrees.
    I'd recommend validating the number of amps you need based on what your electric motor specifies. Look for starting wattage or amperage as a motor requires more current initially to turn on and then it slows down to the running current. If you know the starting wattage, you can use the following calculator to determine the amperage your motor pulls to make sure you get a GFCI plug that will support that current draw. If you don't know your starting wattage, I'd recommend contacting Ryobi.
    https://www.thecalculatorsite.com/co...watts-amps.php
    Super Member VISITOR's Avatar
    May 2007
    9,724
    there's info to the GFCI in the video description, "click more" - looks like it's $17.99
    ELEGRP G1215CA Auto Reset Inline GFCI Replacement Plug Assembly 15 Amp 3 Wires 3-Prongs NEMA 5-15P Grounding for Power Pressure Washer, Pool Pump and More, UL Listed (1 Pack, Black)
  1. another pressure washer is dead, time for an upgrade.....
    By Matt@Revive in forum Auto Detailing Tools and Accessories
    Last Post: 01-08-2017, 01:17 PM
  2. Electric pressure washer
    By Ruben12 in forum Auto Detailing 101
    Last Post: 11-13-2016, 04:18 PM
  3. Electric pressure washer ?
    By Kams229 in forum How to make money detailing cars
    Last Post: 04-05-2014, 07:48 PM
  4. My electric pressure washer is dead!
    By BenSRT in forum Auto Detailing 101
    Last Post: 08-01-2012, 08:57 AM
  5. Replies: 6
    Last Post: 10-28-2011, 03:11 PM
