Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Super Member Buster906's Avatar
    Feb 2016
    871
    Re: Question about pressure washers
    My question is; will a electric pressure washer with 1500 psi be enough for a foam cannon? I do not have a foam cannon yet. What pressure do I need for a foam cannon?
    Dec 2017
    GreenWorks 1700 PSI is great a pressure washer to do enough foam cannon. Personally, I have a suggestion for you, If you want to use this for cleaning your car, I think GreenWorks 1700 PSI is for you.
    GreenWorks 1600 PSI Reviews in 2018-Best Pressure Washer. You can read this article, they reviewed about much electric pressure washer that is under 2000 PSI.
    http://bestwasheradvisor.com/1700-ps...-washer-review. It's also great.
  3. #13
    Sep 2015
    2,173
    Quote Originally Posted by Buster906 View Post
    1500 psi is certainly enough to power a foam cannon. For optimum results, you'd be well-advised to purchase the smaller (1.1mm) orifice for the foam cannon. Will you get better foam from a higher (likely gas powered) pressure washer?...yes you will. I bought the SunJoe SPX3000 based on reviews, and it's so nice not having to worry about whether or not it will start, dealing with the noise, and smelling the exhaust.
  4. Thanks Buster906 thanked for this post
  5. #14
    Dec 2017
    Nowadays, SunJoe is one of the best brands of Amazon.
  1. Pressure washers?
    By AlwaysLoyal in forum Product Reviews
    Last Post: 07-11-2014, 10:02 PM
  2. pressure washers
    By 808_detail_nut in forum Auto Detailing 101
    Last Post: 04-12-2014, 03:05 PM
  3. pressure washers
    By jimjc in forum Auto Detailing 101
    Last Post: 06-10-2013, 05:06 PM
  4. Pressure Washers...and you
    By JonFD in forum Auto Detailing 101
    Last Post: 05-29-2012, 04:14 PM
  5. Question about pressure washers
    By new2detailinginnj in forum Auto Detailing 101
    Last Post: 10-22-2008, 06:27 AM
