Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    Jul 2016
    3,328
    Re: Bought this from Costco!
    What do u guys estimate the pressure at the coin op is. It seems well over 2000
    Super Member Goonie75's Avatar
    Feb 2017
    696
    I have a very strong gas powered pressure washer. Honda motor. over 3000... cant recall exactly. Ryobi from HD I think. I don't put it close to the paint at all. Mainly for the wheel wells and to rinse the dirt off prior to the foam cannon experience... i did find this link... i hope it's okay to post it... it was from a quick Google search...
    peace
    Talkcarwash: Discussions - Self Serve Car Wash - pump pressure
  3. #13
    Junior Member ACCLAY's Avatar
    Mar 2017
    49
    Got it today! Spent about 15 minutes putting it together and another 15 trying to figure out why it had no pressure! I felt stupid when I put the tip on and it worked like a charm! Tomorrow it will be put to good use by doing my wifes little red sports car!
    ​@FREAKIN52 AUTO DETAILING!
  4. Likes Goonie75 liked this post
  5. #14
    Jun 2013
    Montreal, Quebec
    3,996
    Quote Originally Posted by ACCLAY View Post
    Yes, it is amazing how little water come out of the wand without a tip on
  6. #15
    May 2017
    72
    Nice find!!
    I'd throw away that red nozzle. You'll never use it for anything, especially washing cars.
    A 40 degree nozzle with 3.0 and or 3.5 orifice would be perfect for that machine. Either would help knock down the pressure a little bit so you wont have to worry about anything.
  7. Thanks ACCLAY thanked for this post
    Likes ACCLAY liked this post
  8. #16
    Super Member Audios S6's Avatar
    Oct 2011
    Shoreview, MN
    1,634
    Quote Originally Posted by fightnews View Post
    I don’t think it’s well above 2000, I think the difference you feel/perceive is a higher flow rate compared to the average stand alone pressure washer.
    Static & Mobile detailing in Minneapolis & St. Paul. http://www.detailedcreationsmpls.com/
  9. #17
    Sep 2015
    2,171
    This discussion is precisely why I went with a SunJoe SPX3000 (rated 2030 psi) for doing vehicles. More than enough power to clean....not so much power that i have to worry
  10. Likes JRP liked this post
  11. #18
    Mar 2017
    49
    Quote Originally Posted by briarpatch View Post
    I’m not worried about the pressure. 9 times out 10 it will have a foam cannon on it!
  12. #19
    Jun 2013
    Montreal, Quebec
    3,996
    Don't skip the pressure rinse step. A pressure rinse will remove far more dirt and grime than a foam bath ever can. If you combine both you can expect to remove as much dirt as it is possible without touching the paint. But if you only do a foam bath and then rinse off with a hose, it will be far less effective than pressure rinsing without using any soap.
  13. Thanks ACCLAY thanked for this post
  14. #20
    Mar 2017
    49
    Oh I did use the pressure rinse!
  1. Costco for supplies
    By asp125 in forum Auto Detailing 101
    Last Post: 02-07-2018, 03:20 PM
  2. New Meguiars wash & wax at costco
    By saturn2 in forum Auto Detailing 101
    Last Post: 03-15-2017, 01:39 PM
  3. Lifetime tables from Sam's/Costco
    Last Post: 03-07-2017, 07:11 PM
  4. Costco MF question
    By KMdef9 in forum Auto Detailing 101
    Last Post: 02-22-2016, 08:02 PM
  5. MF's from Costco
    By gundie22 in forum Auto Detailing Tools and Accessories
    Last Post: 07-21-2009, 04:51 PM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
