Re: Suggestions appreciated before I purchase
That system is very impressive. The first time I used it, I was blown away. Sometimes I consider using the D300/DCMF exclusively for my cutting, then using my favorite foam pads, polishes, and sealants to finish.
Best results are usually realized by following manufacturer instructions. If you do this with the DAMF system from Meguiar's you probably won't be disappointed.
I haven't tried the D302 yet. I've seen it work great with a yellow Rupes microfiber pad as a one step polish process. In my experience, Ultimate Polish worked great with that pad as a one step.
Originally Posted by Zubair
Been using a toothbrush on Megs,Optimum,Rupes MF,Surbuf,Carpro wool/mf etc with great results. Can't imagine not using a toothbrush on them to get them clean in a hurry. If you don't have access to a compressor, a toothbrush works well.
Just a heads up.
The blue Rupes pads have a looped fiber, unlike the most other mf pads. Maybe Buff and Shine has looped fiber too - I'll have to look later. Using the normal, pad conditioning brush can pull the fibers out of the pad if used to aggressively. I destroyed about four or five pads by cleaning them with that brush. Instead, I moderately brush them out while the machine is turned off, then wipe with the microfiber towel. This has helped with the longevity of these pads on particular.
I really like the microfiber pads and d300. Looks like a great setup, my first setup was nearly identical except for the polisher.
Just get enough fresh pads on hand and void all that time wasted cleaning them while doing a detail job every minute counts get in and get out.
By BTLew81 in forum Auto Detailing 101
Last Post: 08-07-2019, 08:56 PM
By rchamp03 in forum Ask your detailing questions!
Last Post: 06-23-2016, 02:42 PM
By KeepItSteezy11 in forum How to make money detailing cars
Last Post: 06-13-2014, 03:06 AM
By 4x4aholic in forum Ask your detailing questions!
Last Post: 11-22-2013, 06:17 PM
By Damnhor2 in forum Auto Detailing 101
Last Post: 04-26-2010, 08:41 AM
