Hey yg1829,
No problem it had been a while since Snellvillauto posted about this as his post regarding parts was posted on page one so I may or may not get a response which is understandable.
I will atleast post what I have learned so far about the SPX3000
https://images-na.ssl-images-amazon....RL._SX522_.jpg
1) Easy to setup, took me about 20min in total from unboxing to getting everything put together.
2) Unit out of the box work well
3) MTM Foam Canon Attached easily to the standard SunJoe Wand using a 1/4" quick disconnect.
4) Matt from Obsessed Garage as well as allot of other people on this forum and other forums are correct about a few things that become annoying very quickly:
- Pressure Washer Hose is way to short that came with the unit unless you feel like dragging the pressure washer everywhere.
- Installing the MTM Foam Cannon on the front of the long wand is manageable but very unstable
- the stupid M22/15mm fitting that they use on the machine are extremely stupid. there is no reason for this at all SunJoe could have used M22/14 fittings which almost every manufacturer uses (note who used M22 fittings) ( I will be writing a long letter to SunJoe about this as this is completely stupid)
5) Action Plan Going forward:
- Swap out SunJoe hose with Norther Tools's (NorthStar Nonmarking Pressure Washer Hose — 4000 PSI, 50ft. x 3/8in., Model# 989401980)
- Install NorthStar Pressure Washer Quick Coupler — 3/8in. Female, 4000 PSI, Brass, Model# ND10003P on Both ends of hose
- Install M22 Female 15mm Twist Connect x 3\8 NPT Female (Non Standard M22 Connector) - EBay Item onto SunJoe Wand & Pressure washer along with 3/8" Coupler
- Use MTM Hydro M407 Gun (3/8" couple on inlet port with mosmatic swivel) and 1/4" quick disconnect on outlet port. Purchased all of these items on Amazon along with the MTM foam Cannon as a bundle had to purchase the mosmatic swivel seperate.
