why do my towels not absorb like they did when new
I have a stack of micro fiber towels of varying quality, some very plush, some inexpensive. They have always been washed using detergent advertised as formulated specifically for MF towels.
Now when I use them, they act like a dry chamois, they push the water around more than absorbing it. I have even taken to soaking the towels down with water, and then wringing them out before using them.
Today I reached the bottom of the bag of inexpensive towels, and pulled out some that had never been used before, and they were amazing! Super absorbent!
So what has happened to my used towels, what is affecting how the absorb, and is there anything I can do to get them to work like the new towels?
Again, I have only used special detergents, never used softener of any kind, wash in cool water, and dry at low heat - have tried to follow all the suggestions on MF care.
Any suggestions?
Thanks for any help, much appreciated.
Re: why do my towels not absorb like they did when new
I am having the same issue. I suspect wax residue, oils, polymers, residual softener from the drier, and such is having an accumulative effect. I plan to soak my towels in hot water with a strong cleaner (probably a mix of apc, degreaser, mf cleaner, and pad cleaner) and wipe the drier before use from now on.
"I've seen a good quality car wash look better than some guys complete detail jobs."
Mike Phillips 10/21/09
I personally think they just get old. The fibers start to shrink and clump up through repeated washing and drying. Plus there might be residual wax or sealant in the towels that don't get washed out thoroughly. I had towels that I used for waterless washing with Megs D115 and they never seem to wash clean unless I ran them through multiple cycles. Might be even residue detergent too. Some advocate boiling towels in a pot to restore the towels but I've never tried it.
I had that problem for a long time. I started putting a little Microsoft detergent in the softener spot on the washer and run it through a rinse cycle with nothing in the machine, and that's after I pull the softener tray out of the washing machine and rinse it out good. That way and fabric softener residue in the washing machine plumbing and the inside of the machine itself are washed away before I wash my towels. I've replaced most of my towels in the last few months so I can't tell you for sure if that's helping. I rarely use wax, mostly coatings and sealants.
2015 F-150 Crew Cab Lariat
2016 Chevrolet Camaro 2SS
This might seem out of the norm but drench your drying towels until they are soaking wet. Hand wring them very well and star drying away. IMO a damp MF Towel dries better than a completely dry towel. Try it. I will usually follow the damp MF towel with a plush MF towel. I would encourage trying that and see your results. I no longer dry my ride any other way.
CJ
Save the Manual!
Easy fix...boil them in water, add vinegar for extra umph.
Simpler , Easier answer
Start using Hot water everytime you wash
The detergent needs the assistance of the hot water to dissolve the oil, grease and LSP residue
Beware of those giving suggestions without evidence of their results.
I only wash my drying towels with my other drying towels and never with towels that contain lsp. Also my lsp towels never need to dry water they are strictly for lsp. It's prolly overkill but it works. It may help that my washer has never seen liquid fabric softener.
Sent from my SM-G920V using Tapatalk
A couple of Ideas !!!
(1) Using to much soap, in cycle. Use vinegar in rinse cycle. To remove excess soap and soften.
(2) On some washers the soap and fabric dispenser is at the top and water passes thru them. I check and clean them out before I use ..
(3) What LSP are you referring to. Possible cross contamination. Sealant dried before washing, etc.
What are you using for soap or dedicated MFT cleaner. ???
Mike !!!
Mid-Michigan
Tri-Cities
WITH
Towels need to be washed in HOT water.
Even if your water is 140° (which it'll still mix with at least SOME cold water) even that's not going to be too hot for microfiber towels.
You can use a mixture of APC and microfiber detergent as a presoak. Better yet... spray APC directly onto your worst towels before the presoak. Let them soak in your washer for an hour or so, then program your wash for a heavy load, at least a 'regular' cycle (IE not delicate), with an extra rinse, extra spin.
Then dry them on medium heat.
I have a cycle programmed into my washer that takes over 2 hours (including the presoak).
By animescreen in forum Auto Detailing 101
Last Post: 07-23-2019, 01:25 AM
By Meghan in forum Auto Detailing 101
Last Post: 01-28-2018, 11:25 AM
Last Post: 11-27-2017, 01:57 PM
By mwoolfso in forum Product Reviews
Last Post: 12-30-2014, 10:33 AM
By ScottB in forum Car Care Product Giveaways
Last Post: 11-07-2008, 08:38 PM
