Results 1 to 6 of 6
    Junior Member batcat420's Avatar
    Sep 2014
    Atlanta, GA
    47
    Question Issue with pressure washer and water tank
    I have a 35 gallon water tank going straight into a gas pressure washer. I'm having issues because the water in the tank isn't freely flowing, not quick enough anyway, to supply the washer with enough water to operate properly. Is this a matter of gravity or do I need some sort of pump? It's inconsistent and I'm worried that I'll damage the pressure washer. Any help or ideas are appreciated.
    Here's my setup.
    He who makes a beast out of himself gets rid of the pain of being a man.
    Ragtime Detailing
    May 2014
    Northern Vermont
    1,400
    Re: Issue with pressure washer and water tank
    You may want to post what type of pressure washer you have. Some require water be pressurized some do not.
    Super Member VP Mark's Avatar
    Jul 2012
    2,451
    You need a pump. I have a sureflo on demand pump I don't use anymore. Already wired for 110v. PM me.
    Visual Pro Detailing - Auto Detailing near Marion, IL. Call
    (618) 983-9706 www.visualprodetailing.com
    Junior Member ngonzi's Avatar
    Oct 2012
    76
    Looks like you need to mount the tank higher than the pump. To achieve more gravity
    Dec 2014
    Boonsboro, Md
    2,724
    Is there a vent in the tank to allow air to get in, or to prevent a vacuum in the tank?
    Or you could try it with the top cracked open. You may still need a pump though.
    ____________
    Aug 2011
    Yes the tank needs to be higher than your pump. A pressure washer does not like to pull water. The higher the tank the more pressure you will get. You can calculate the pressure using P=rgh Pressure = r(density of water) G=gravity(9.8m/s or 32.2feet/s h=height(in feet or meters). Make sure you units are constant. Also you can calculate the flow in GPM by the cross section area of the hose. Run the numbers and see what you need to get 3GPM.
  1. Replies: 12
    Last Post: 12-13-2017, 08:25 AM
  2. 275 Gallon Water Tank w/3000 psi Pressure Washer?
    By art72 in forum Auto Detailing 101
    Last Post: 01-05-2017, 01:46 PM
  3. Another Water tank to Pressure Washer thread
    By Mattdamobster in forum Auto Detailing 101
    Last Post: 09-12-2016, 06:12 PM
  4. MOBILE SET UPS (pressure washer & water tank
    By 215Detailing in forum Off-Topic
    Last Post: 11-27-2015, 03:35 PM
  5. Water Tank and Electric Pressure Washer
    By KJW Detailing in forum Auto Detailing Tools and Accessories
    Last Post: 11-26-2012, 06:27 PM
