Dynamic duo for rubber and trim-clean+black
I hope I am learning from my mistakes.
Now I need to know, what would make a great one - two knock out punch for the following problem:
1st remove all silicone, and other greasy dressing from faded rubber and plastic followed by a real clean, safe, permanent black dye which can later have non=silicone preserative added without the black coming off?
SELF BANNED
Why do you want to dye them?
The reason for wanting to dye is because the rubber seals and some plastic under the hood are horribly faded. No amount of "dressing" or other rejuvenation stuff is able to bring back the color.
Sounds like the Forever Black kit is what I need. Will the Forever Black stuff work on both rough or textured surfaces as well as some fairly smooth, but very faded rubber too?
Yes it will
Ed
Moderator/Consultant for Autogeek.net
To achieve excellence, excellence cannot be rushed. Technique is just as important as the product used.
While my approach takes more time, the results are far superior.
Here is a pic of the back window seal. No matter how many different products I tried, so far none have kept it looking black for more than 3 days.
That is the most effed up window seal I have ever seen. What did you do to that thing?
Don't know if this will work for you or not (your seals look worse than mine did) but...
Last week I decided to try and do something about the seals on my 99 Jeep Cherokee, they looked like they had lepreousy or something...
I ended up using a 1:1 diluted APC and Mr. Clean Magic Eraser - this really cleaned them well. They went from feeling very rough to smooth and looking a almost like new. I followed that up with an application of DG 271. Can't speak towards durability yet.
By Grifffx4 in forum Auto Detailing 101
Last Post: 10-18-2014, 07:54 AM
By alexxxx89 in forum Auto Detailing 101
Last Post: 07-25-2014, 11:44 PM
By op1001 in forum Auto Detailing 101
Last Post: 04-16-2013, 04:21 PM
By natt2000 in forum Ask your detailing questions!
Last Post: 12-31-2012, 06:55 AM
By subiefish in forum Auto Detailing 101
Last Post: 08-19-2009, 05:53 PM
