You'd better hurry up, I think those BOGO's are going to be changing momentarily. That lime "green" pad is the new LSP pad sposed to be same as the red, I think the "light green" is the AIO/light cutting of which you speak.
i will also add the lime green(not a lime green to me looks more grass green) is as setec said the wax pad thats the same as the blue/red pads. the green polishing pad color is more of a light seafoam green color. the bogo pads are the same as the 5.5 flats or 6.5/5.5ccs same colors minus one new pad to stop cross contamination of products. as far as the 6.5's go i hope your buying them for a rotary or flex as the pc's dont provide the best correction with a 6.5, that extra inch makes a world of difference.
Yellow = Cutting
Orange = Light cutting
White = Polishing
Light Green = Light Polishing/Finishing
Gray = Finishing
Green = Waxing
Red = Waxing
Blue = Waxing
Nick,
Can you give a little more info on each waxing pad? I'm wanting to place an order today.
i.e., type of foam, absorbent or not, jeweling or not. I thought AG offered a gold flat pad as well? Your preference for waxing/sealant/jeweling, or for an AIO?
