Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Senior Member David Fermani's Avatar
    Apr 2007
    Metro Detroit
    682
    Lightbulb How to make your favorite Clay last alot longer!
    This method will dramatically increase the lifespan of your clay. I wouldn’t be surprised if it lasted atleast 5 times longer just by following this easy procedure.
    Hint: If your clay is cold and stiff, soak it in a bucket of hot water and fold or knead your bar. Within 2 minutes it will be soft and good to be used.
    Work your clay as usual. Back and forth, circles....what ever way you choose. As you work the clay, try to inspect it and discover a “baseline” for how quickly the bar picks up contaminants and gets clogged/discolored. If your work area is quite listen for abrasion noise created from your clay eating into the contaminants. No noise is usually an indication that the surface is free of heavy contaminants. Don’t wait for your clay to get too dirty because the dirt embeds itself to the face of the clay and ultimately gets rubbed into/against the surface creating unnecessary marring.
    This is about as dirty as your clay should get (Clay Magic blue pictured):
    Take your clay, spray any water based APC (I prefer Optimum Power Clean) and liberally spray it onto the surface of the clay. Then, take a clean toothbrush and agitate the surface of the clay. This will loosen up the contaminants.
    Take the clay and submerge it into your bucket of water, rubbing the clay with your fingers and rinsing the suspended debris off the surface.
    Note: method not effective for 100% road tar contaminant removal. These contaminants are best removed prior to clay process.
    Knead clay and repeat often>>>
    Metro Detroit's Leader in Vehicle Preservation & Perfect Paint Finishes
    Senior Member Porsche Pilot's Avatar
    Jun 2010
    Florida
    1,745
    Re: How to make your favorite Clay last alot longer!
    Great tip David. I will toss that little tip in my cranial tool box. Thanks!
    ED aka Porsche Pilot
    Senior Member Old Tiger's Avatar
    Oct 2009
    Up State SC
    4,468
    Great idea David! BTW can you update your Opti-Coat aka Opti-Guard post? TIA!
    Senior Member CEE DOG's Avatar
    Jul 2009
    Florida
    7,358
    That's a good idea Dave! I rarely let mine get that dirty but I like this tip.
    :dancebanana:
    Sky's the Limit Car Care
    Senior Member kronos's Avatar
    Jul 2009
    Los Angeles
    1,404
    Thanks for the tip David. I definitely go through quite a bit of clay.
    Now does anyone know how to make clay less sticky???
    Enrique - Amateur Detailer Extraordinaire
    "Man is an emotional animal, occasionally rational; and through his feelings he can be deceived to his heart's content." - Durant
    Senior Member IID's Avatar
    Sep 2010
    Northwoods
    2,132
    Seems like a great tip,Thank You David.
    Team Flex PE14-2 150(Serial#0005)/3401/3403
    Senior Member Dubbin1's Avatar
    May 2009
    3,845
    Quote Originally Posted by kronos View Post
    Soak it in oil :D
    Sep 2010
    Northwoods
    2,132
    Quote Originally Posted by Dubbin1 View Post
    Soak it in oil :D
    Senior Member pfix's Avatar
    Jul 2010
    St. Louis MO.
    493
    Great Tip David. Thank you for sharing it with us.
    Are you using diluted APC to clean or full strength?
    Paul
  10. #10
    Senior Member cutter's Avatar
    Mar 2011
    Clanton, AL
    526
    Great Tip!!! Thank you!!
    My name is Jeff and I like to make things SHINE!!!
  1. Quick DIY: Make your favorite spray bottle work upside down
    By cshamilton in forum How to Articles
    Last Post: 03-04-2014, 11:03 PM
  2. Will Riccardo Clay Ever Make It Here (USA)
    By Flash Gordon in forum Auto Detailing Tools and Accessories
    Last Post: 10-16-2013, 09:45 AM
  3. how many of you are no longer using clay?
    By VISITOR in forum Auto Detailing 101
    Last Post: 10-01-2012, 05:51 PM
  4. What is your favorite Clay?
    By Bamaboy007 in forum Auto Detailing 101
    Last Post: 02-27-2012, 07:30 PM
  5. What is your favorite clay?
    By Joshs2013MSAltimaSL in forum Auto Detailing 101
    Last Post: 02-01-2009, 12:35 AM
» July 2017
252627282930 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31 12345
