Re: How many times can you buff?
Wondering about that myself, noob here.
This is why you use the least aggressive method first. Lots of people want to go right to M105 which is a compound. Give 205 by itself a try, or even menzerna power finish. With proper wash technique you should not need to polish all the time. For my twice a year polish I use 85RD, and maybe bump it up to 106FA. Last time I used dodo lime prime because the paint was fine.
Really interesting post, thanks.
The purpose to use something like Menzerna PO203S and after Menz Final Polish PO85RD.
PO85RD is used to clean the paint after a more intensive polish so the paint will be perfect for a sealant and wax ... am I right ?
Great advice. I normally only need to go around my black car with po87mc and a blue pad twice a year to keep it swirl free. I am always happy to make multiple passes if time allows since I am a big fan of try to remove as little as possible to achieve the level of correction I am looking for.
PO85rd has much finer abrasives which allows you to remove any marring that previous steps have left behind. It also jewels the paint but this is done via mechanical abrasives so it doesn't 'clean' the paint in the strict sense of the word; it focuses if you will.
folks, I appreciate the replies, but they still don't answer my question. Please don't threadjack and change the subject of this thread.
Yes, I understand that you must use the least aggressive method first and see if that takes care of the swirls. If it doesn't then move to next aggressive. Fine, I understand all that... but still, my question still stands.
How many buffing sessions can a standard vehicle' clear coat withstand? For sake of the discussion, assume Porter Cable, M205/105, LC white/gray pads.
Come on folks, all you experts out there. Someone HAS to know. Someone out there must have made the mistake of "buffing through the clear coat". For those of us without a clear coat thickness measuring device, we would like to know before we buff "too much".
2012 Ford Mustang 5.0 - Kona Blue Christened name: MARILYN
2012 Acura TSX S.E. - Silver Moon Christened name: TORI
2013 Toyota Prius V - Blue Ribbon Metallic Christened name: PORTIA
I have used power finish 203 by itself w/a soft green LC pad as a one-step. It's almost the same as wolfgang TSR 3.0. With a more aggressive pad, yes, you would follow up with a finishing polish like 106FA or 85RD. 85RD does have cut and can remove light imperfections on paint by itself, 106FA has more cut. Always try to save your clear coat. 106FA with s soft green LC pad can remove swirls too, but minor ones only.
85RD is also used to jewel paint. Lets say you use SIP with a white pad, then 106FA on a grey pad. You can then use 85RD with a blue pad to jewlel(shine it up even more) the paint as your 3rd step.
You can't get a definite answer ot the question. That's why professionals still use a paint depth guage. What type of car, what polish/compound has been used, with what pads, has it had body work, how old is it and etc. I could go on.
Thanks to christian900se and loudog2.
Sorry sportscarhiatus for the threadjack... I'm out.
By Jmbrown415 in forum Auto Detailing 101
Last Post: 01-20-2017, 08:49 PM
By mcpp66 in forum Ask your detailing questions!
Last Post: 05-28-2012, 07:52 AM
By Derek Short in forum Auto Detailing 101
Last Post: 04-15-2012, 05:09 PM
By keeotee in forum Ask your detailing questions!
Last Post: 07-12-2010, 11:42 PM
By rousher99 in forum Off-Topic
Last Post: 11-12-2008, 09:43 AM
