Mercedes SL63 drivers door
Close up down to the primer substrate
Thickness of surrounding clear/base
Prep with sanding pen and cleaning solvent
Air brush reduced color
Carefully lay a bead of 2k clear
After clear has cured level down to surrounding clear/base
Check thickness of surrounding paint
Wet sand with 2000 to entire repair area
Correct the clear to remove sanding marks
Total repair time 1hr. Total time with car 2 days including a detail
