Re: Is there a sealant like product for black plastic. Rear truck bumpers, running boards, etc.
Hydro Blue, Or plastic trim restorer.
I use Hydro Blue on big pick up trucks in the plastic wheel wells, Provides nice protection against mud/grime buildup.
Originally Posted by mengelhardt
Is Meguiar's Ultimate Black Trim Restorer the same as Ultimate Black Plastic Restorer ?
I see both a Plastic Restorer (G16910) in an aerosol can, and also a Plastic Restorer (G15812) in a squeeze bottle? But the only Trim Restorer I could find was a 2-pack of sponges.
What is the difference between these products and which one do you use? I noticed the squeeze bottle at $6 was several dollars cheaper than the aerosol can at $8, and a two-pack of the sponges was $3.
Are these all the same product, just different delivery/application methods?
The sponges and the squeeze bottle are the same product. The aerosol is a tad different. The aerosol is meant to last longer but the issue with aerosol's is overspray. Any overspray with this one is a pain to remove.
If you are looking to pick up any of these then the squeeze bottle is the better buy. Like all trim protectants prep is the key. Cleaning the trim will allow the trim protectant to bond and last longer on the plastic. Ultimate Black will net you around a month before it needs to be reapplied.
McKee's 37 trim restorer is good. Seems to be holding up well on my cousins car.
Wolfgang Exterior Trim Sealant is another good one.
Originally Posted by BadgerRivFan
Can one use Dlux on truck/Tahoe running boards? Was wondering if it would leave it too slick?
Thanks
Ryan
Sent from my SM-G965U using Autogeekonline mobile app
Thanks
Ryan
I do not know about Dlux, I went with the Wolfgangs and never looked back. It has an awesome shine to it and it doesn't make the plastic slick.
I like McKees Plastic Trim Restorer.
It is very similar to, and just as good as WETS, but has a better price point.
It does have more of a darkening effect on older trim than WETS does, and it works great on new trim. It’s not just for restoring.
Both are easy to apply and plastics won’t look worse once it past its life.
Some of these coatings can be a pain to apply and I believe some can look bad(possibly if over applied) at the end of their life.
____________
Originally Posted by JeffsRealm
Thanks all I knew there had to be something. I am going to try the Wolfgang right now. I already had it in my cart for an entirely different reason, I just changed to an 8oz bottle and will give it a go.
The Wolfgang Exterior Trim Sealant (WETS as most call it here) is a very nice product. Perhaps a little pricey, but a little goes a long way. It has good durability against washing and rains, and is not a product that will be running down upon other parts of a vehicle, it stays put.
Some have said they've used it on Tires, but I prefer other more economical products specifically made for such. Commonly Optimum Opti-Bond Gel and Optimum Tire Shine.
You'll perhaps also find as I have, that WETS is also very outstanding on all Rubber Weather Stripping and other rubberized components on a vehicle. Really gives the rubber a clean, black, and better than brand new look, and a very soft supple feel.
Guz mentioned good prep. What’s the best way to clean rubber/matte plastic trim prior to Sealant application, other than car wash or waterless? APC?
Just have to make sure there's no dirt or grease. Like when you glue or paint stuff, you have to make sure the surface is clean.
Sent from my Mi A1 using Tapatalk
Another vote for the McKee's 37 product. Great durability and I'm pretty happy with it.
By jackb88 in forum Ask your detailing questions!
Last Post: 06-02-2018, 08:34 AM
By glh17 in forum Auto Detailing 101
Last Post: 08-28-2014, 10:46 AM
By Wxc in forum Ask your detailing questions!
Last Post: 04-02-2014, 11:11 AM
By bonedr in forum Auto Detailing 101
Last Post: 02-21-2014, 04:53 PM
By 1flyfisher in forum Ask your detailing questions!
Last Post: 11-22-2010, 07:54 PM
