Results 1 to 5 of 5
    Super Member YankeeFan's Avatar
    Dec 2006
    607
    Quick headlight restoration question
    Sorry to bother you with this but I don't see an answer or just don't know all the acronyms used
    Once I go through wet sanding with 1000, 2000 and/or 3000 grit what is next? Use a DA or rotary? What pad and how aggressive a polish to work with? I have Menzerna products.
    Plan IPA wipe-down, then apply DLux
    Thanks
    Nov 2014
    149
    Re: Quick headlight restoration question
    Quote Originally Posted by YankeeFan View Post
    Thanks
    Looks like you have the process almost dialed in! My personal preference after sanding with 3000 grit, is a 4" Buff and shine orange pad on my PE14 using M100 (Or FG400 in your case). I've used my GG6 with this same pad with great results, but I prefer the speed and precision of the Rotary.
    Finishing down is up to you. FG400 will probably finish down LSP ready on polycarbonate lenses.
    Brandon Visser | 269-569-1900 | b5visser@live.com
    Owner/Appearance Specialist | @domainappearance
    Dec 2006
    607
    Quote Originally Posted by B5visser View Post
    Thanks for the clarification. Planning on trying this tomorrow.
    Super Member brettS4's Avatar
    Jan 2015
    Wisconsin
    649
    You probably could skip the 3000 wet sand. I usually go from 1500 to M105 and then M205 on my GG6 and call it quits when the plastic seems to disappear. But you gotta play it by ear and see what works. The nice thing about this sort of correction is that it's very clear (no pun intended) how well it's progressing.
    The polycarbonate is fairly soft so you won't need a very aggressive pad. You might end up backing up a step once or twice if it looks like sanding marks were left after the polishing. But maybe that's just me being a perfectionist.
    Nov 2016
    KY
    1,065
    Here's my method just for the helluvit:
    Clean with Meguiar's Mirror Glaze 17 Plastic cleaner
    Clay the surface
    Wet sand with 1500, 2000, 3000 and distilled water
    Compound with PE-14, 1"-4" orange pad, and any compound that I have extra of, or don't like for paint
    Polish with PE-14, 1"-4" white pad and Meguiar's Mirror Glaze 10 Plastic polish
    Seal with Chemical Guys Jet Seal
    Probably overkill, but they look great. Everybody has a different method.
    Kirk Harrod's Mobile Detailing, Frankfort, KY
    Official Detailer of Camarofest 8 & 9
    No one has detailed more Camaros.
  1. Quick headlight restoration ?
    By idriveblackcars in forum Auto Detailing 101
    Last Post: 08-20-2016, 05:51 PM
  2. Quick Headlight Restoration Question??
    By BrianJM in forum Auto Detailing 101
    Last Post: 04-22-2016, 04:54 AM
  3. Quick headlight restoration
    By FFguy808 in forum Show N' Shine
    Last Post: 10-02-2013, 10:59 PM
  4. Quick Headlight Restoration
    By Newdetailer1 in forum Show N' Shine
    Last Post: 08-08-2012, 02:13 AM
  5. A quick headlight restoration
    By dontsleeponit in forum Show N' Shine
    Last Post: 11-17-2007, 07:05 AM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
