Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Jul 2016
    1,739
    Re: Help me find a Glaze with fillers for this process...
    I'd get the menzerna glaze or chemical guys. The finishkare has abrasive.
    Mar 2016
    If what I have doesn't work out or it's effects disappear quickly under FK1000p, I'll try something else. I'll be splitting the rear trunk on the Honda and I'll take pictures after each wash.
  3. #13
    Senior Member Desertnate's Avatar
    Aug 2013
    St Louis metro (Illinois)
    2,783
    Both Poorboys and Prima Amigo will work well under most sealants and waxes.
    I like Poorboys Black Hole for it's filling ability and overall appearance, but I actually use Amigo when going for a glaze due to its mild cleaning/abrasive properties. It will work like a paint cleaner and glaze. It also is VERY easy to use.
    Save the Manuals!!
  4. #14
    Senior Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    18,304
    Quote Originally Posted by fightnews View Post
    Which Menzerna and Chemical Guys
    Glazes are you talking about. Thanks.
  5. #15
    Apr 2014
    366
    Quote Originally Posted by CarolinasFinestDetailing View Post
    If you're already pulling out your machines; may as well grab some HD Speed. While it doesn't "fill"; you can literally buzz over the surface super quick and enhance the surface rather than filling. Go over the whole car then remove where you started.
    Agree with this. If you're worried about removing clear coat, use something like Menzerna SF 3800.
  6. #16
    Member
    Oct 2016
    98
    Why hasn't anyone mentioned CarPro Essence with a Microfiber pad?
  7. #17
    Mar 2016
    I worked on the grey metallic Honda Civic, polishing with Jescar Correcting Compound on Orange Pads. I found with the Flex 3401, that the thin Lake Country worked best with this polish and polisher. Correcting Compound didn't get out all that I wanted the first time, had to go back 2-3 times in some cases. The car still has some faint marks but it think they are deep in the clear. The previous owner seems to have likes brushes and was aggressive with them. Snow scrapers in particular to the point where I had to touch up 2 spots around the window. Car look fantastic in comparison and I'm a critic for sure.
    Poor Boys Black Hole went on super easy, darkened a bit, and I'm sure filled where possible, but didn't hide what I could not get by polishing. This surface was just polished so there wasn't much for it to fill. The Jescar Correcting Compound finished down so well, that I didn't need to do a light polish. Black hole on trim (by mistake) resulted in black trim. I was happy so I did the rest of the trim with it too.
    I waited 24hrs and topped it all off with FK1000p. Let's see what happenes over time...
  1. products that have fillers without being "a glaze"
    By octane in forum Auto Detailing 101
    Last Post: 03-07-2014, 11:58 PM
  2. Can't seem to find process time spread sheet
    By T3 AutoDetails in forum How to make money detailing cars
    Last Post: 05-15-2013, 12:05 AM
  3. Glaze with fillers questions
    By Vjeszczi in forum Auto Detailing 101
    Last Post: 08-06-2010, 02:20 PM
  4. Process - Glaze, Paint Sealant, Wax?
    By Mike Moore in forum Ask Mike Phillips your detailing questions!
    Last Post: 01-12-2010, 03:56 PM
  5. one step or glaze with fillers
    By imageautodetail in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 03-25-2008, 08:25 PM
» October 2017
1 2 3 4 5 6 7
8 9 10 11 12 13 14
15 16 17 18 19 20 21
22 23 24 25 26 27 28
29 30 31 1234
