Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Senior Member Route246's Avatar
    Mar 2017
    508
    Re: CR Spotless - Water Hardness Determines Resin Life?
    Quote Originally Posted by Route246 View Post
    There is a YouTube video out there where a guy recharges his resin with muriatic acid and lye in two stages as I had suspected. It looks easy for someone who likes detailing. Looks like you can recharge for less than $10 worth of chemicals.
    I'm hacker/tinkerer do it looks like an interesting project. Probably pickup a DI system soon. Need to wash windows around the house now, too, and rinsing with DI water it will make things very easy with nothing to wipe or clean for spot-free window panes, especially the high ones and the skylights on the roof.
    https://youtu.be/eqz44sNprkE
    Hopefully this YouTube link works.
    Senior Member 2black1s's Avatar
    Jan 2015
    367
    Quote Originally Posted by Ernie Mccracken View Post
    Saltwater aquarium hobbyists make a lot of 0 TDS water and they almost all use reverse osmosis to clean the water before it goes through the DI resin (the most expensive part). The RO can actually bring the TDS down to 10-15ppm, which is pretty much bottled water at that point. The order of operation is usually something like-
    carbon block prefilter (coarse) --> carbon block prefilter (fine) --> RO membrane --> DI 1st stage --> DI 2nd stage
    The downside of RO is that it adds complexity, produces waste water (you can use it on your lawn or whatever, though), and also needs to be run at semi-regular intervals to keep from drying out. But if you want hundreds of gallons of 0 tds water per month, that's the way to go. A DI only system makes most sense for the weekend warrior washing a couple of cars per week.
    My homemade system is the configuration you've described... RO first, then DI.
  3. #13
    Mar 2017
    508
  4. #14
    Mar 2017
    508
  5. #15
    Mar 2017
    508
    Quote Originally Posted by 2black1s View Post
    That is pretty awesome. How much does a decent RO system cost to front-end this rig? I want that, I want that, I want that...
  1. Those wondering about foam thickness and water hardness...
    Last Post: 06-20-2014, 12:03 PM
  2. Recent increase in water hardness
    By mfrickman in forum Auto Detailing 101
    Last Post: 05-01-2014, 07:40 PM
  3. tap water hardness 120, distilled or not?
    By twobucket in forum Auto Detailing 101
    Last Post: 02-01-2014, 11:36 PM
  4. I Tested My Water Hardness
    By swanicyouth in forum Auto Detailing 101
    Last Post: 06-22-2012, 10:25 AM
  5. What Determines Sealant Life when Layering
    By Fog Runner in forum Auto Detailing 101
    Last Post: 04-04-2007, 02:40 PM
» December 2017
2627282930 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
