06-07-2017, 11:45 PM
#141
Re: Flex 3401 vs. Rupes Mille/Makita P5000C, for those that are wondering.
if you look at this up to 1:12, you'll notice it's in the free spin mode and it looks like it's barely rotating as well...
06-08-2017, 12:19 AM
#142
Originally Posted by JustJesus
huh, they really did. That sucks.
I guess those guys weren't aware of unwritten rule #1. "Don't hassle the Hoff"
06-08-2017, 08:26 AM
#143
Originally Posted by ScottH
Thanks for that video.
I think it demonstrates where the spin comes from in random orbital machines - that is, leverage against the bearing coming from the pad and binding of the bearing.
When the machine is running at lower speeds and the pad is flat, the leverage friction of the pad against the paint is pretty much the same everywhere but that friction has greater leverage over the bearing at the outside edge, so, the plate runs counter to the orbit of the shaft.
When the pad stops spinning it's because the binding of the bearing is equal to the leverage exerted.
When the pad spins in the same direction as the orbit of the shaft, it's because the binding of the bearing is greater than the leverage of the pad against the paint at the outside edge.
I'm finding this thread really interesting.
If there was only one cause for the spin, speed wouldn't matter.
RSW
06-08-2017, 10:55 AM
#144
Thanks Scott. I really do want to be believed I'm not crazy. Neither are you, or anyone else seeing it "change direction."
I still believe it's the wagon wheel effect.
Here are some videos that hopefully show what's happening. One is kind of "nerdy" and may explain it better than I can.
ANNNNNND, if you're a car guy, maybe this can "show" the effect using a car's wheel, as it's moving forward. With this last sample, there is no way the tire is changing direction as it's moving forward!
06-08-2017, 08:18 PM
#145
....wagon wheel effect it is! I did one final test this evening. I held the polisher backing plate on my hand while in free spin mode. With my hand in contact with the backing plate, I turned the polisher and and moved from speed one through five so I could feel the pad rotation. Although it still visually appeared to be switching direction at the higher speeds, it in fact didn't. I think the reason why we are seeing this and not on other polishers is the unique notched design of the backing plate.
ScottH
06-08-2017, 08:24 PM
#146
This car was wrapped over the top of a bunch of scratches and swirls. Unwrapped and polished. The wheels are going to be replaced and I'll take care of the wheel wells while the wheels are off.
The entire correction to this finish was done with the Makita PO5000C in about 5 hours. For me, because I've been running the BO6040 since it came out in around 2002. I've still got some touching up to do but the machine worked great.
RSW
06-08-2017, 08:26 PM
#147
RSW happy to hear that. Did you do the entire car in gear driven mode?
ScottH
06-08-2017, 08:29 PM
#148
RSW
Looks great! Did you use it in both modes or mainly forced rotation? Do you feel the Makita corrects quicker and more effectively than the flex 3401? The car looks great!
Sent from my SAMSUNG-SM-G935A using Autogeekonline mobile app
06-08-2017, 08:32 PM
#149
ScottH
Yes and at 5 with my left hand on the trigger, right hand at the top. Also, very little hand rubbing and no tape.
How are you liking yours?
RSW
06-08-2017, 08:40 PM
#150
Like I told Scott, all in forced rotation and full speed. I ran my Makita BO6040 head to head with the other machines and it was faster and this is maybe half again faster than that.
It took about a quarter of the car to get comfortable with the smaller pad size and shape of the machine but after that it was a joy to use.
RSW
By Dan Tran in forum Auto Detailing 101
Last Post: 10-25-2019, 05:52 AM
By Trevine in forum Auto Detailing 101
Last Post: 03-15-2019, 04:04 PM
By TTQ B4U in forum RUPES BigFoot Oribital Polishers
Last Post: 10-22-2018, 08:26 PM
By minirips2 in forum Ask your detailing questions!
Last Post: 04-16-2018, 09:36 AM
By Mike@ShineStruck in forum Auto Detailing 101
Last Post: 12-23-2017, 02:47 PM
