Re: 114 replacement
The only thing I use D114 for is claying vehicles that will be going through a full correction and coating treatment. I really like the idea of the product rinsing free and leaving nothing behind on the surface. Is N914 similar to D114 in lubricity and cleaning power when used as a clay lube?
Re: 114 replacement
IME, yes. I was using it today at 1:128 to clean some door jambs that were filthy - the dirt was literally running off. I was very impressed. I just finished using a 16oz bottle of it and will be getting a gallon soon. I have been using that as a clay lube to compare to D114 and it works just as well.
Re: 114 replacement
I've never used a rinseless or waterless wash yet but want to try them I usually only have dusty and the normal bird droppings is the N914 good for that ? Also what's the easiest process for using it ? Thanks
Re: 114 replacement
I think you're right in the sweet spot for using it. Many different processes for using it. Read up on Waterless Wash. I'm sure Mike has an Autogeek video on the process (sorry - too lazy to check for link). I use a modified Garry Dean method, which is a lot of MF towels. Other people use a grit guard with one or two buckets. I've decide I don't ever want to use wash water with any dirt in it, hence using Garry Dean method. (I have a sponge as well for very dirty areas - different topic.)
If I can I will hose off my car first. Not necessary, but I like to get as much dirt off touchless as I can. I may spray it with Waterless wash as well using a 1.5L pump sprayer. Can't always do this. I like to hose, soap it, and hose again. Sometimes just hose, sometimes just soap. Then take my MFs to it. You can use a mitt or a sponge if you don't want to go through many MF towels.
Generally clean a panel and wipe it dry. When I go too far without drying I generally get some streaking and have to take Waterless wash to it again to remove streaks.
Re: 114 replacement
Originally Posted by RippyD
Pros may notice a difference. For those of us maintaining several cars, I find N-914 to be very close replacement for D114. I don't miss 114 at all. If you liked D114, I have a hard believing you won't also like N-914.
For the person who wrote that D114 had more cleaning power, maybe increase the concentration of N-914 a little? It does seem less soapy/foamy than D114, but it doesn't clean any less well at similar concentration. I tend to use it at 128:1 vs. 1:256 for rinseless, so that could be why I don't notice any difference.
thats what I would do
By brad2388 in forum Auto Detailing 101
Last Post: 04-15-2020, 02:14 AM
By nickyc in forum Flex Polishers
Last Post: 05-10-2018, 06:50 PM
By mswerb in forum Auto Detailing 101
Last Post: 02-26-2014, 12:53 AM
By Reddwarf in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 05-28-2012, 08:13 AM
By StephenK in forum Products Guides
Last Post: 07-07-2011, 11:11 AM
