Re: More aggressive pad? Or more aggressive compound?
Originally Posted by expdetailing
First, if your not on speed 6 with 15 lbs of downward pressure, try that. If that still does not cut it, I'd go with a 5" backing plate (better at cutting and polishing than the 6") and some microfiber pads (cuts better than foam), and if that doesn't work, get a more aggressive compound.
I am using speed 6. If I push down to hard the plate stops spinning. It needs to be spinning right?
Originally Posted by shagnat
How "bad" is it to use 6" pads? Since the backing original backing plate fits them very well...... I hope I didn't waste money on my 6" pads.
6" pads can work. They just take longer because they distribute the work over a larger area than smaller pads. When you move to the sides of the truck, that aren't covered in water spots, they could work well. A ram is a lot of paint to polish.
Since I'm a visual person, here's Mike P saying how to polish a car with a PC. It's a 3 part installment.
