Cleaning wheel barrels when Rinseless washing
How do you guys clean inside the rims? I usually use a rim brush when I use water, but it doesn't seem like it would work using one without quite a bit of water.
Do you guys just spray them down and wipe with a MF? And the barrels just don't get cleaned?
Recently did a Lexus IS350F that has High performance brakes and they were bad.
I sprayed them with ONR and used a MF the best I could. I just couldn't clean them inside very well...
David 2000 Ford F-350 DRW CCLB BLACK/GOLD
Wish list:
Everything Mike has in his garage for detailing
Re: Cleaning wheel barrels when Rinseless washing
I assume no pressure washer?
I would say if he had a pressure washer available there would be no reason to do a Rinseless Wash or clean the wheels with ONR. You could wash the car with car soap (two bucket method) and just spray the wheels with Sonax Full Effect and then rinse. Does this sound correct?
Yes...
that's basically how I do inner wheel barrels,
inside very well...
Without access to free-flowing water sources
(including pressure washers); and, when not removing
tire/wheel assemblies from the vehicles; I find that
there are, quite often, limitations to the total amount
of inner wheel barrel cleaning that can be accomplished
whenever I'm using RWs/WWs.
If the wheels have enough room, I just get in there with a cotton terry towel and wipe it down then toss the towels after.
In my opinion the whole point of a Rinseless Was is to be able to detail a car anywhere without a water source. The Rinseless Wash also saves water and does not produce runoff with chemicals that will flow down the storm drain and contaminate the water supply. It's much more Eco Friendly and meets EPA regulations in drought stricken areas. Plus you can wash your car in the garage in the winter
This was just recently posted if you haven't seen it.
http://www.autogeekonline.net/forum/...heel-wash.html
I use my normal products to clean with and I use a pump sprayer filled with water to rinse with and agitation with my brushes to help, or I use my rinse bucket and brushes similar to the method in the video in the link above.
____________
I use microfiber towels, a demoted wash mitt, or wheel woolies.
In my opinion, wheel woolies are one of the best ways because they carry so much solution.
Another good/cheap option is just getting a grout sponge and cutting it in half.
2017 Infiniti Q60 3.0t AWD
I have a 2 gallon hand pump that I use to clean the wheels and barrels. I always have wheel cleaner so I have never used RW solution to clean my wheels. I have wheel woolies and I guess I could use the old solution but what I do there is this:
I take a cleaned out empty cat litter jug and place one of my mf gloves over the opening and pour in the old solution. The mf glove acts as a filter and you can actually see particles going into the glove. When done and when I'm done wiping out and rinsing the buckets I just pour the filtered solution back into the jug, add 2 ounces of fresh RW mix and fill the bucket to 3 gallons, done.
Sorry, I know this goes off the tracks a bit but it will surely help someone out.
2022 Elantra N Cyber Gray
That is correct, no pressure washer.
Wish list:
By Eldorado2k in forum Auto Detailing 101
Last Post: 12-23-2018, 05:44 PM
By Spiney in forum Auto Detailing 101
Last Post: 08-10-2012, 09:59 PM
By builthatch in forum Auto Detailing 101
Last Post: 02-23-2011, 11:07 PM
By Shawn T. in forum Show N' Shine
Last Post: 02-06-2011, 02:13 AM
By TLMitchell in forum Auto Detailing 101
Last Post: 05-23-2009, 06:13 AM
