Results 1 to 3 of 3
    Super Member runrun411's Avatar
    Oct 2012
    Dutchess county, NY
    1,789
    How to do a test spot???
    When doing a test spot to try different combos of products do you:
    1 change pads when changing products?
    2 try test spots with various combos?
    3 use eraser after doing the test spot?
    Just curious. Trying to figure out how to do it right.
    Always keep the shine in your life.
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    Re: How to do a test spot???
    I do test spots that tell me everything i need to then apply an LSP. If it's a 2 step cut and buff i first determine the cut method. That may be as many as 3 different spots to determine what specific level of cut i want as the first step. I never hit the same spot again with a different cut product. And i say maybe 3 spots after trying 2 compounds but one of the 2 on 2 different pads. Yes, fresh pad for the next spot and basically, a fresh pad for each product i'm "testing". I rarely mix products on a single pad. Once i determine the first step i then use THAT spot to try what i think the second step should be. I rarely need to try a second product but sometimes that happens. If so, i.e. what i thought the finish step should be re: pad and product isn't as good as i can get, i cut another section and try my next candidate for the "second" step.
    My test spot may yield that i can "persuade" a little more gloss out of this paint with the same product BUT different pad.
    I then use Eraser on the test spot when i have determined what will be my approach around the entire vehicle and see how it looks. Effectively i have determined what looks best for what the customer wants and to a point that just needs LSP. And in the order i'll be working around the vehicle. First step, second step, Eraser.
    Hope that's not confusing and is just the way i do it anyway. I will say i have refined what i think will work pretty fast and rarely do my test areas take more than about 10 minutes.
    Mar 2015
    Puckman really nailed it and only thing I would add is check out mikes test spot how to here:
    http://www.autogeekonline.net/forum/...test-spot.html
  1. How To Do a Test Spot
    Last Post: 09-24-2019, 08:41 AM
  2. Only one test spot?
    By Carlito12200 in forum Auto Detailing 101
    Last Post: 04-29-2016, 08:43 AM
  3. Test spot
    By BennyHFP in forum Auto Detailing 101
    Last Post: 05-19-2015, 08:22 PM
  4. Doing a Test Spot....
    By HUMP DIESEL in forum Auto Detailing 101
    Last Post: 11-20-2014, 02:56 PM
  5. Pic. Of Test spot
    By Slava in forum Show N' Shine
    Last Post: 12-23-2009, 12:06 PM
