Results 1 to 10 of 10
    Jun 2014
    Chandler, AZ
    3,360
    AG sell Foam Gun for standard hose??
    Hi All,
    I don't have an air compressor (yet) nor a pressure washer (yet).
    Does AG make or sell a foam gun that connects to a standard hose?
    Super Member rms64's Avatar
    Dec 2012
    Reno, NV
    1,122
    Re: AG sell Foam Gun for standard hose??
    Sure, here's an example:
    Autogeek Quart Foamaster Foam Gun FREE BONUS
    Just search on "foam gun" in the store - I believe the versions that require a pressure washer are referred to as "foam cannons".
    Hope this helps..
    May 2014
    259
    Quote Originally Posted by rms64 View Post
    Hope this helps..
    And I'll add to his recommendation in that the unit he linked actually works quite well. I have one that I use when I don't feel like dragging out the pressure washers and I have no complaints with it whatsoever. You don't need special soap, your regular concentrated car soap works just fine with it.
    Jun 2014
    Chandler, AZ
    3,360
    Nice! Thank you!
    Aug 2009
    125
    do u need to dilute ur regular soap when using the foam gun? i used the dp soap and it seems too runny when mixing as per directions
    Nov 2013
    Alexandria, VA USA
    1,072
    Which DP wash product are you using? They make one specifically for foam.
    Mar 2011
    PA
    5,792
    Quote Originally Posted by molarman View Post
    Usually 2oz of soap in the resivor then fill with water. *shake*
    Some soaps will foam up better in the gun than others.
    2018 Colorado ZR2
    Super Member medicscott's Avatar
    Mar 2015
    Long Island, New York
    582
    We will be using one on Saturday
    Aug 2013
    Tustin, CA
    4,389
    Man I miss my foam gun!! I have it but it's collecting dust. Here in Southern California The Land of the Socialists and Progressives...we have water restrictions and can't use it.
    We have the Castapo Water Police monitoring our water usage. But I digress..
    IMO the Foam Gun is a great addition to a 2-bucket 2-Grit guard wash.
    Make sure you get the foam gun with the brass mixture adjustment tool not the plastic one.
    CJ
    Save the Manual!
  10. #10
    Super Member 808_detail_nut's Avatar
    Apr 2014
    557
    I have a old one that I still use today. The one with the brass fittings. I lost the top screw so I have to use my finger to plug the hole so I can get good foam. I know I should buy a new one but this one still works. I only really use it on really dirty cars to presoak before I wash. I use megs gold class in it and it never failed to give me a good foam blanket.
  1. Foam Canon and Standard Hose,
    By aliitp in forum Auto Detailing 101
    Last Post: 07-09-2016, 07:26 PM
  2. foam backing wool or standard wool pad? (for rotary)
    By sansa in forum Auto Detailing 101
    Last Post: 02-24-2016, 12:48 PM
  3. Foam Cannon for Water Hose?
    By RBJR in forum Auto Detailing 101
    Last Post: 02-27-2013, 06:12 PM
  4. Should i chuck/sell all my foam pads and replace them with MF ones?
    By Rez90 in forum Ask your detailing questions!
    Last Post: 08-14-2012, 09:45 AM
  5. Normal psi for standard water hose?
    By bshattuck87 in forum How to make money detailing cars
    Last Post: 08-14-2011, 11:54 PM
