Results 1 to 4 of 4
    Mar 2006
    Question Can clear coat line from removed pinstripes be sanded down?
    I removed the pinstripes on a car that I bought last year. I believe that the car had a paint job at some point because after I removed the pinstripes I could see a distinct edge from the clear coat. It appears that whoever painted the car applied tape to the pin stripe (to prevent overspray on the lower panel). There is a very visible edge from the extra clear coat on the top section of the car.
    I'd like to know if this can be repaired via wet sanding and polishing. Can I sand down the edges to flatten them out? Is this a typical problem that detailers see in their day-to-day activities? Anything I should be worried about? I've wet sanded small scratches in the past, but nothing of this magnitude.
    Attached Thumbnails Attached Thumbnails Can clear coat line from removed pinstripes be sanded down?-20150519_142425-jpg   Can clear coat line from removed pinstripes be sanded down?-20150519_142513-jpg
    Mar 2006
    Re: Can clear coat line from removed pinstripes be sanded down?
    This post was a milestone for me as this was my first post since first joining the forum nine YEARS ago! HaHa! SuperLurker.
    Hi SuperLurker!
    The line you see is an imprint in the paint called ghosting
    I've never seen it 100% removed on car paint.
    I think I've seen it 100% removed from the boat we sanded and buffed here at AG last Friday.
    The big difference is gel-coat is thick so lots of room for sanding deep and car paint is thin. If it's the factory paint it's VERY thin.
    My guess is you can improve it but not 100% remove it.
    Mar 2006
    I kind of figured I'd be stuck with some form of the line. I may try to give it a light sanding when I work on the car this weekend. That's *if* I don't become too chicken to do it. Especially since I don't know how thick that section is. Thanks for the input Mike!
  1. Wet sanded through clear coat, fix?
    By keithmfr in forum Wet-Sanding, Cutting & Buffing
    Last Post: 10-26-2016, 09:49 PM
  2. Accidentally sanded through clear coat
    By harpreetgill21 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 07-15-2016, 05:37 PM
  3. Sanded through clear coat - touch up paint help
    By Dorian in forum Auto Detailing 101
    Last Post: 09-12-2013, 01:25 PM
  4. Sanded through Clear Coat on 1999 Chevy Silverado
    By techcode in forum Ask your detailing questions!
    Last Post: 06-24-2013, 01:16 AM
  5. Help! Please! I sanded through my clear coat
    By theparmachine in forum Auto Detailing 101
    Last Post: 05-19-2013, 09:16 PM
