Ultimate Paste Wax - long term update (7 months) ... to be continued.
I'm about to go wash my car. It hasn't been touched since October when I last applied a coat of Ultimate Paste Wax to it. I will be washing it with Deep Crystal car wash and once I'm done, I'll check for beading and sheeting (or lack thereof). Unfortunately, I can't post pics, but I will be as descriptive as possible
...to be continued...
Re: Ultimate Paste Wax - long term update (7 months) ... to be continued.
Excited to read the update. i was looking into purchasing Ultimate Paste/Liquid Wax to compliment D156.
Those two can be a potent combo!
Ok, all I have right now is a laptop and my camera won't connect to it. This is an outside car: 24/7/365 with an average of 94 miles round trip to work. Except for the hood and the right front fender, the car is single-stage red Suzuki Aerio. It's not a beater, it's my primary car, I just don't get to clean it up in the winter, I don't have anywhere to take it and a coin-op only gets so much dirt off ... I don't use coin-ops for anything ... so the car was never cleaned since Oct.
First, I started with the rims and tires, using Simple Green a brush and an old mf for the rims. I know, I know Simple Green isn't the best choice, but my CC aluminum rims are already peeling and corroding ... how much more damage can *I* do? Then I rinsed off the car using a heavy spray. Some areas (front fenders before the tire, A-pillar and the tops of the doors) did sheet some, but it was slow. The horizontal surfaces looked dead, no beading or sheeting with the rinse off.
Using a new microfiber wash mitt and a mild solution of Deep Crystal car wash, I started on the roof. I could immediately feel the drag on the mitt almost as though I were rubbing it against a Velcro panel. Since it's cloudy and cool, I washed the entire driver's half of the car, switching to an older lamb's wool mitt for the lower half of the car. Unlike the mf mitt, the lamb's wool glided smoothly over the surface. Then I rinsed that side of the car with the heavy spray. There was no immediate sheeting or beading that I could see, but after watching for a few minutes, I noticed that the vertical panes of the car did kind of sheet, although VERY slowly. The hood, roof and trunk appeared dead. One weird thing: The A pillar, which runs over the windows and becomes the C pillar around the back window WAS beading the water. Not great, but it was noticeable and occurred fairly quick after the shower of water was moved away.
Then I went to the passenger side and repeated the process with nearly identical results. Again the A pillar was the odd one out and beaded water. I didn't dry the car I just walked around it watching the actions of the water The vertical panels were *sheeting* a little faster and there were now individual lines of water droplets going down the sides. The hood was full of flat, weak beads, but you could see a pattern of lines running from the top of the hood to the front edge. And the roof, which I had thought completely dead, was nearly dry with only a few areas of water droplets remaining.
I had to end my observations there because OF COURSE it started to rain ... heavily. But I did watch out of the window and saw the same pattern of very slow sheeting. When the rain stopped, I went back outside to discover that the majority of the water was no longer on the car, the car was covered in flat, weak water beads and the roof was nearly dry (with a fresh coat of wax, my roof will hold hundreds of water beads until I drive away or dry them off, it won't dry like that). At that time, I could have easily used some Ultimate Quik Detailer and finished drying off the car.
And of course it started raining again and I had to stop my observations.
What does this all mean? I have no idea. Is there a miniscule amount of wax left? Is the water reacting the way it was because the wax was gone, but the car was highly polished before it was waxed?
Now just for giggles, let's look at the appearance side of the coin. Once all of the stuck on dirt was removed, the car still looked really good, not perfect, there are some minor defects that need polished out and you could see that when the water was pooled on the paint, the color was a lot darker than the dry areas (it looks the same color wet OR dry after a good polish/wax). Of course this could just be a result of the ss paint fading over the winter, no surprise there.
Well, I hope you got something out of this ... what I got out of it is that my car needs some Ult Polish and some more Ult Wax SOON.
Just a comment regarding coin-ops. During the winter, using them to remove the salt and grime is a very good idea. The car won't be perfect but most of the dirt will be gone and most importantly, the salt and calcium will be gone and won't be able to attack the metal on your car.
If you have not touched the car at all, the wax should still be there. If the car is dirty, you won't get beading or sheeting but once you wash it properly it should return.
I know I'm going to ruffle a lot of feathers, but my understanding was that Megs' sealants and waxes had quite poor durability.
What was your reason for choosing that product for your pre-winter LSP? I'm not saying you chose wrongly, but sometimes that answer is as simple as, "It's all I had at the time," and that's totally fine. I am just wondering what made you go with MUPW.
No washes is quite a torture test!
Meg's waxes are made for people who like to wax; durability isn't as much part of the equation for someone who is doing it every change of the season. I used to be that person.
I used Meg's Ultimate Wax (sealant) up until I coated my car. I only reapplied it once in a year, and that was only because I polished. I did use also use Ultimate Quik Wax though, so I can't really say if UW is durable on its own.
Meguiar's sealants are actually pretty good. Give them a try. They last like any other typical sealant. 4-6 months is about the right amount of time for ultimate wax.
UW IS pretty good. It's easy to use, looks good, and durable. Hit it with some D156 every few washes and it will extend the durability quite a bit. I'd rate it up there with 845 in terms of durability, though I know some will disagree.
I happen to like Megs and I'm on a budget and I don't feel the need to go out and buy the higher end stuff that might give me a month or two more durability. I also happen to like polishing and waxing my car, for me it's great stress relief. I'm sure if I had been able to wash and apply some UQW regularly, the results might have been more favorable. Too, the fact that my car has SS paint might have had an adverse affect on the longevity.
You're not the first person I heard make the same statement regarding 845 and UW.
Don - The SS paint should not matter. It's probably all the salt, snow and grim that got to it. D156 makes a perfect counterpart to UW.
By emilime75 in forum Auto Detailing 101
Last Post: 04-14-2018, 01:19 PM
By Justin at Final Inspection in forum Auto Detailing 101
Last Post: 01-07-2017, 02:09 AM
By Don M in forum Auto Detailing 101
Last Post: 11-23-2014, 05:02 PM
By Jomax in forum Auto Detailing 101
Last Post: 07-20-2012, 06:49 PM
By boogiejoe in forum Auto Detailing 101
Last Post: 04-04-2008, 09:57 AM
