Almost Time for 1st Paint Correction..Appreciate Input
I'm going to do my first paint correction soon, since the warm weather is almost here. I'd appreciate input on product selection i.e. what's a compromise between ease of use and results. I want good results, but if a product is hard to use then it doesn't do me any good. Here's the breakdown:
Vehicle- 2013 Alpine White M3. It is a daily driver.
Paint Condition- Fair (scratches and swirls visible in the right lighting) but "good" under normal lighting..isn't that the case with white cars. I would post pics, can't get the damage to show. To quote "Bones" from Star Trek.."Damnit Jim, I'm a doctor not a photographer" :LOL:
Equipment- 7424XP and CG hex logic orange, white, black, red, blue pads x3
I'd appreciate input on the following:
1) product i.e. good for beginner. I'm considering WG vs. Menz, but open to anything
2) Pads- stick with Hex or LC Flat
3) Regimen- I was considering skipping the full correction on the lower panel, bumpers (since its a DD and they get the most wear) and using AIO instead...thoughts? Product recs?
4) Goal- I don't need a show stopper..it is a daily driver but I would like to get a good result i.e. a majority of scratches out.
5) IPA wipedown vs. Speedwipe?
I know I'm asking a lot, but I'd appreciate some experienced peoples opinions.
Thanks!
Re: Almost Time for 1st Paint Correction..Appreciate Input
1) Wolfgang lineup
2) Lake Country Hydro tech
3) As this is the first correction, why not correct everything from the get go?
4) The above advice will get you where you need to be.
5) If using the Wolfgang lineup a panel wipe isn't needed. But if you want to ensure the paint is stripped then you can perform an IPA wipe. Make sure your mixture is around 17.5%
I have used an extensive list of Wolfgang products and they are incredible for new users and seasoned vets alike. You can not go wrong with the Wolfgang lineup.
Should I invest in a 3inch backing plate and pads?
@Mike, thank you for the input. Just wondering why you recommended the hydrotech vs. the flat pad. I thought "thin was in"
Mike, Where would you put P21S paint cleanser in the scheme? I purchased it b/c I heard it really helped with white paint. It seems to have some abrasive technology. Would this be more like a maintenance item or prep for correction?
I would put the P21S Paint Cleanser in the same spot where you would use Wolfgang Paint Work Polish Enhancer, BlackFire Gloss Enhancing Polish, and so on. That is after you compounded and polished the paint.
If you were to use this product after a compounding/polishing session I would use the P21S on a black finishing pad.
This could also be used as a maintenance product as well combined with a light polishing pad.
BTW, this product is only for use when a wax or sealant is going to be utilized.
By Justin at Final Inspection in forum Show N' Shine
Last Post: 07-24-2019, 08:43 AM
By Coleroad in forum Show N' Shine
Last Post: 03-21-2018, 12:59 PM
By MattK1 in forum Show N' Shine
Last Post: 03-20-2017, 11:05 PM
By PugDog in forum Auto Detailing 101
Last Post: 03-01-2016, 05:51 PM
By iceman978 in forum Auto Detailing 101
Last Post: 11-08-2011, 03:17 PM
