View Poll Results: How many of you use a MACHINE to WAX your vehicle?
Voters
123. You may not vote on this poll
  • All the time
    53 43.09%
  • Half the time
    37 30.08%
  • Never use a machine
    33 26.83%
Page 18 of 20 FirstFirst ... 891011121314151617181920 LastLast
Results 171 to 180 of 197
  1. #171
    Mar 2016
    35
    Re: How many of you use a MACHINE to WAX your vehicle?
    always hand wax. Reluctant to use machine because I fear I will damage the paint. Also from what I read hand waxing is quicker
  2. #172
    Nov 2015
    Los Angeles, California
    13,729
    Quote Originally Posted by Zalmon View Post
    It won’t and it’s not.
  3. Thanks PurpleTowel thanked for this post
    Likes Avgguy, PurpleTowel liked this post
  4. #173
    Super Member Route246's Avatar
    Mar 2017
    NorCal - San Mateo County
    1,037
    +1.
    Just machine waxed with my GG3 today. Incredibly fast to apply, much, much faster than hand application could ever be. The real value is the application is even, consistent and thin, which is very difficult to achieve by hand.
  5. Likes Avgguy, PurpleTowel liked this post
  6. #174
    Jun 2017
    126
    I only use a machine for correction work, I prefer having the control doing my waxes or sealants by hand.
    Sent from my SM-G935V using Tapatalk
  7. Likes Eldorado2k, hoyt66 liked this post
  8. #175
    Nov 2015
    13,729
    Quote Originally Posted by Cleankat View Post
    I feel the same way.How many of you use a MACHINE to WAX your vehicle?
  9. Likes Cleankat liked this post
  10. #176
    Apr 2012
    7,494
    The major advantage of machine application besides it being much faster which equals efficiency, machine application gives you the ability to apply the product in a much more consistent uniform manner. One of the most common complaints I've read over the years on this forum is about lsp's and removability. In many cases that is due to over application of product and is usually due to hand application. You also use much less product when applying by machine.
    It is virtually impossible to get this type of application by hand.
    Polish Angel Cosmic Coat
    How many of you use a MACHINE to WAX your vehicle?-pacosmiccoat-jpg
    Polish Angel Viking Coat
    How many of you use a MACHINE to WAX your vehicle?-escalateviking5-jpg
    PAVC 4" B&S Pad Rupes Duetto
    That is enough to do the entire sdie of my Nissan Rogue and then some.
    How many of you use a MACHINE to WAX your vehicle?-vikingcoat1-jpg
    2019 Nissan Rogue SL
  11. #177
    Nov 2015
    13,729
    Quote Originally Posted by custmsprty View Post
    And 1 of the drawbacks is not having as much control around edges/rubber trims. It presents a problem not only because some lsps aren’t plastic/rubber trim friendly and also because even if they are, you run risk of turning your pad black if you accidentally go over them, and I don’t like the idea of applying lsp with a caked black pad, even if it’s minimally stained.
  12. #178
    Apr 2012
    7,494
    Ever heard of tape? As far as losing control, that is totally operator dependent.
    To each their own, you go your way and I'll go my way.
  13. Likes Avgguy liked this post
  14. #179
    Nov 2015
    13,729
    Personally I don’t have that issue because my choice of sealant doesn’t stain trims nor do I apply it via machine so my applicator stays clean for the most part.
    But generally speaking people don’t like to go through the trouble of having to tape down everytime they wax their vehicle.
  15. Likes hoyt66 liked this post
  16. #180
    Super Member RippyD's Avatar
    Jan 2016
    Portland, OR
    1,246
    I get more even application. When applying this thinnest coat of something it's the way to go. I use a DA with a waxing (non-cutting) pad. I apply by hand more often, but likely get better results with the DA. As far as trim, I just do those areas first by hand so I don't have to get my pad right up against the trim.
    2006 LR3 White // 2014 Boxster Agate Gray // 2012 Sentra Aspen White
    Sealant test resultsxxxxxDilution ratio chartxxxxxWheel cleaner info
  1. Hello! I got a new vehicle!
    By RS 25 in forum Introduce Yourself
    Last Post: 04-15-2018, 01:21 PM
  2. PPF prep on 3 yr old vehicle
    By originalgoods13 in forum Auto Detailing 101
    Last Post: 03-03-2017, 07:51 PM
  3. 1966 Corvette Stingray - Machine Polish & Machine Wax
    By Mike Phillips in forum Show N' Shine
    Last Post: 05-04-2016, 07:27 AM
  4. Detailing Vehicle / Personal Vehicle
    By KJW Detailing in forum How to make money detailing cars
    Last Post: 12-04-2012, 11:14 PM
  5. What does your vehicle look like right now?
    By ICEMAN in forum Show N' Shine
    Last Post: 02-07-2011, 04:41 PM
