Results 1 to 8 of 8
    Regular Member Burns ST's Avatar
    Jul 2013
    107
    How to remove interior moisture?
    How can I remove moisture from the interior of my car?
    I had a service clean my carpets of my car and they forgot to close my sunroof. The car sat for about 8 hours before I picked it up tonight and the damp air got inside.
    Super Member oldmodman's Avatar
    Sep 2007
    2,563
    Re: How to remove interior moisture?
    A big fan inside the car blowing air across the inside from one window out the other usually gets the inside of my cars dry overnight in a garage.
    But I am in Los Angeles and it's mostly quite dry and low humidity here.
    Jul 2013
    301
    I've used one of these in the past when storing a vehicle for a long period of time
    http://www.damprid.com/moisture-odor...rber-bags-work
    Super Member Don M's Avatar
    Jan 2010
    NE Ohio
    2,247
    Are you in an area where it's still warm/hot outside and you can leave the car in the sun with the windows up and the sunroof open?
    Super Member aim4squirrels's Avatar
    Nov 2013
    DFW Texas
    1,078
    A day with the windows open or the doors open will fix it, provided it isn't raining outside.
    Aug 2013
    St Louis metro (Illinois)
    5,795
    Quote Originally Posted by aim4squirrels View Post
    I typically do this all summer long when I park in the garage at night. I at least leave a couple of windows open and often the sunroof too. It keeps the car aired out and the condensation in the vents from the A/C giving the car that musty odor.
    Super Member tigerwash's Avatar
    Jun 2014
    300
    leave all the doors and windows open on a sunny day. that or try a fan
    Jul 2013
    107
    I've heard running the ac system on recirculate with the sunroof cracked helps suck it out, but I've had no such luck.
    I have these little sponges called Z-Rust. They've got a pellet inside that helps draw in moisture. Giving those a shot.
  1. Can you help How to remove mold from car interior
    By Stephen McLachlan in forum Ask your detailing questions!
    Last Post: 08-13-2020, 05:08 PM
  2. Moisture in headlight?
    By fightnews in forum Off-Topic
    Last Post: 02-13-2018, 01:47 PM
  3. layering times ..curing away from moisture?
    By Rod73 in forum Auto Detailing 101
    Last Post: 05-20-2015, 06:45 PM
  4. Just curious: Sealants vs quick exposure to moisture
    By Hoytman in forum Auto Detailing 101
    Last Post: 12-20-2012, 09:35 PM
  5. HELP!! How to remove black from the interior??
    By SheldonH in forum Auto Detailing 101
    Last Post: 05-31-2012, 10:06 PM
