Sealant bonding
I do a rinseless wash after polish. I read to many bad things about IPA wipe downs. Will the sealant bond if there's still some polish residue
Re: Sealant bonding
you read bad things about an IPA wipe?
Also, don't overthink this all so much.
Back to the full-time grind.
Well everyone talks about it not having lubrication
Re: Sealant bonding
the concept of using ipa wipedown is to remove any residue before applying sealant; this will aid in sealant bonding after polishing
What do you mean about not having lubrication? That's pretty much what the alcohol is removing all the lubricant that would interfere with you sealant bonding as well.
Re: Sealant bonding
What polish, rinse-less, sealant are you using?
Re: Sealant bonding
Look into Carpro Eraser, I had never ending trouble with Poorboy's Exp not lasting. I bought some eraser for when I cquk'd my truck and afterwards, on a buddy's car I ended up using Exp but I used eraser before it and now I'm on month 4 and it's still there.
Re: Sealant bonding
I've posted and shown pictures of wiping with IPA can mar paint. You can really only see this on black but the point is if it's happening to clearcoated black it's likely happening to all clearcoated cars it's just your eyes can't see the marring on light colored paints.
If you mar the paint after polishing to perfection this is what I call working backwards.
I agree, too often people take something that is quite simple and turn it into rocket science.
As it relates to bonding people want to get the best bond between the product they are using to protect the paint and the paint so there will be maximum adhesion between the protection ingredients and the paint.
Makes sense on some levels but I've posted info from a real chemist that states it's not what most people think.
Zaino products actually started or pushed chemically stripping paint over the tipping point back in the early part of 2000 and ever since then people want to strip their paint using some type of hot solvent.
2 Points
1. Most people hanging out on a detailing discussion forum will re-apply "something" sooner than later so longevity isn't the biggest issue.
2. I've never walked out into a garage after waxing or sealing a car with a paint sealant to find the product all piled up on the garage floor surrounding the car because it didn't "bond" and therefore slipped off the paint.
See this article...
Miscible and Immiscible - Wax and Paint Sealant Bonding
I use meguiars 21 sealant. I've read that alcohol doesn't have lube and it's possible that it can cause marring. Some people say put some rinseless wash in with the alcohol. I just want to know if it's that important. I compound, polish then finishing polish then wipe it with something like ONR then seal
Re: Sealant bonding
Correct. IPA is the opposite of an oily lubricant. In context of detailing cars it's used to DISSOLVE oily films so they can be removed.
Because it's not a good lubricant, it doesn't help to lubricate the surface when you're wiping, thus the microfiber towels plus the pressure from your hand can leave marring in the paint.
Marring is the kind, gentle fluffy way of saying scratches.
Here's the article I wrote where I posted pictures of marring on clearcoated black paint.
Hologram Free with a Rotary Buffer
If it were me? I'd keep it simple.
Wipe off the polish residue after polishing and then machine apply the M21. Allow it to dry and then enjoy your shiny car.
Last Post: 08-03-2020, 09:14 AM
By Nate3420 in forum Auto Detailing 101
Last Post: 06-12-2013, 06:17 PM
By RPPM in forum Auto Detailing 101
Last Post: 02-16-2012, 04:56 PM
By LegacyGT in forum Auto Detailing 101
Last Post: 11-13-2010, 02:19 PM
Last Post: 11-01-2010, 02:59 PM
