Car maintenance
I know this is. Not detail related but i just bought an 02 jetta with 257,000 miles.5 speed what would u guys reccomend to keep it running good other than change the oil
Sent from my LGL35G using AG Online
Re: Car maintenance
Do you what's been done in the past? I would start with a tune up for sure
Re: Car maintenance
Depends on engine. 2.0 4 cylinder or 1.8T? This is the best forum for this answer:
VWVortex.com
I`m active on it as well.
Re: Car maintenance
basics would be fluids/oil, filters, spark plugs.
2.0 Non turbo and had timing belt 100k ago and eater pump and coils had clutch and flywheel 2 yr ago
Re: Car maintenance
Your ready for another timing belt now.
Re: Car maintenance
lucky his lasted, my 2004 audi a6 had it fail at low mileage and almost brand new
Bill 1234
2004 audi a6 quattro (traded).
2015 Ford Escape 2.0l ecoboost 4WD
Re: Car maintenance
Get a Chilton repair manual for your car and it will have a detailed maintanence schedule. It will also explain how to do it.
Also join a forum for your car and you will learn a lot about it.
Got a pic of the car all detailed out?
Volkswagen Golf/Jetta/Cabrio, 1999-2002 (Chilton's Total Car Care Repair Manuals): Chilton: 9781563924897: Amazon.com: Books
Re: Car maintenance
Suspension will have to be replaced, shocks only last 75,000 and none of the components have most likely been changed. Many people neglect their suspension as it is easy to not fix worn parts there.
If you really want to know exactly what needs to be done to it take it to an auto shop and ask them to perform a PPI (Pre Purchase Inspection) for you.
Re: Car maintenance
As an ASE Certified automotive tech, your on borrowed time with that timing belt. Get it done first. A good shop is going to ask if you want to do the water pump as well, and you might as well since the tech is RIGHT THERE. Also, timing belt idler and tensioner pulleys need to be replaced with those miles.
Your struts are most likely trashed. Wen you do the front struts, make sure you do the strut mount as well. The rear are not that important, but the front have to move with every turn of the steering wheel, and wear out over time.
Since you got a 5 speed, get the manual trans fluid changed out. Make man sure they use the right fluid.
Your going to find that parts are going to be a little more expensive for your VW. And god help you when the engine light comes on...not a lot of repair places work on European vehicles. The scanners are expensive, the software is expensive, the tools to fix them are expensive, and that cost gets passed on down to you, when we get a Euro aE, we refer them to a euro car specialist.
But hey...you got the car of your dreams !!
By prin in forum Show N' Shine
Last Post: 03-29-2018, 12:15 PM
By ct18 in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
Last Post: 12-18-2015, 03:09 PM
By M+O in forum Auto Detailing 101
Last Post: 09-04-2010, 06:54 AM
By marchese_alexander in forum Auto Detailing 101
Last Post: 02-13-2008, 01:51 AM
By FloridaNative in forum Auto and Garage Accessories
Last Post: 06-25-2007, 05:17 PM
