Results 1 to 6 of 6
    Super Member parttimer's Avatar
    Aug 2013
    1,564
    Booking my first subie
    I was contacted by a co-workers friend looking to get her 2012 WRX STi done this spring. She bought it has her winter "beater" until she found out the cult like following it has. Its a garage queen now. So, as I have read, subie paint stinks I am looking for ideas on products to use. It should be in great shape, but we all know how that goes after a washing. I have the full line of Menz, Rupes and Wolfgang products along with Rupes pads, hydrotech and CCS pads. I have a feeling it will get CQuartzed when done.
    Anyone with some starting suggestions?
    Super Member wrb_subie's Avatar
    Feb 2013
    456
    Re: Booking my first subie
    I use m205 on the ones I've done and I've done quite a few. Super soft so start easy cause it doesn't take much to cut which will make for an easy detail
    Super Member WillWashesCars's Avatar
    Jul 2013
    Long Island, NY
    318
    Be gentle with it. M205 should work but if you find yourself facing "sticky paint" which many of them have. You will have to modify your technique with any polish or compound. Wet buffing towels will become your friend.
    Super Member lawrenceSA's Avatar
    Feb 2012
    Durban - South Africa
    1,713
    I have only done 2 but I can tell you that the paint is very soft.
    In both cases nothing more than Menz SF4000 was needed and I think I LC crimson and Menz Black finishing pad were needed, used with a DA polisher.
    Given how easily I corrected the 2 I did with this combo, I would really err on the side of caution when starting your test spots regime.
    You may be surprised at how easily you can correct it. Rather not remove any more clear coat than is absolutely necessary
    Here are the links to the 2 in question should you wish to assess the results
    Java Black Pearl Subaru Impreza WRX - Detailed by Lawrence
    Obsidian Black Subaru Impreza Sti - Detailed by Lawrence
    I hope you enjoy the experience and it doesn't present you with any major issues.
    As for the stickiness, I am pretty certain that this would be compounded by the use of a rotary where the heat would be higher. Not that I think you need to use one.
    Post up some pics and let us know how it went.
    Aug 2013
    1,564
    Thanks Lawrence, I have that menz and pad, I don't have whatever you used the black pad for though, I imagine if I needed a little topper I could use the Rupes white pad and ultra fine polish. I'm thinking I might pick up some microfiber madness towels if I confirm the booking.
    Super Member ShinyRex's Avatar
    Jan 2011
    Virginia
    417
    Quote Originally Posted by lawrenceSA View Post
    I concur, I have a 2011 and every day imperfections come out easily with SF4000 on a crimson HT pad. Deeper stuff took a tangerine pad and v36, but that was the exception. The only place this didn't hold true was on the plastic parts. They took a lot more work.
    Sent from my SCH-I535 using Tapatalk
  1. Subie Snax's Garage
    By SubieSnax in forum Show N' Shine
    Last Post: 10-27-2020, 08:55 PM
  2. Time management/appointment booking
    By Onthegeauxauto in forum Auto Detailing 101
    Last Post: 12-04-2016, 10:15 PM
  3. Anyone use Joomla with an appointment booking module?
    By JWilliams.RadiantDetail in forum How to make money detailing cars
    Last Post: 07-19-2015, 02:20 PM
  4. Online booking
    By AeroCleanse in forum How to make money detailing cars
    Last Post: 05-12-2014, 03:28 PM
  5. Winterized my Subie with Duragloss
    By micvog in forum Show N' Shine
    Last Post: 10-14-2012, 03:15 PM
