Master Blaster, compressed air or leaf blower?
What do you think? Hard to justify 300 for the master blaster, I have an air compressor, is just a leaf blower the way to go?
Re: Master Blaster, compressed air or leaf blower?
I haven't tried the other 2 options but I have a Master Blaster and its well worth it. I barely use a towel after I'm done using the MB to dry the car.
all 3 will work just fine.. do you want to completely dry the car with air or are focusing getting the water out of the small areas?
im sure its well worth the money (leaf blower does not compare to MB as far as power) but if your new or barely picking things up, spend $300 on more products, tools, etc..
The SideKick will be great to get all the small areas, MB will get most water but it wont really reduce time, leaf blower will remove most water, but will take longer
I've had a Master blaster for 2 years one of the best things I've bought for my business.
I've had a gas leaf blower for years and it works great for drying the family cars, (while wearing ear protection). Have also used the shop-vac.
Any of the three will get the job done.
Smoke Metallic '06 Altima
if you have the money then go for the master blaster. if you sheet as much water off as possible, then using the leaf blower will do just fine in getting the majority of water left over. you'll still have some droplets left behind in which a waffle weave/microfiber towel can take care of. if your car has a good coat of wax/sealant/coating then the water will fly right off alot easier...
I use my $28.00 leaf blower, it removes most of the water, I then wipe down the entire car using a QD and sof MF towel.
I'm sure the MB is a fine unit but I can't justify speeding that much money on it.
I'm sure if I was to buy one I'd think how I got along with it but my leaf blower works for me
If you use a compressor remember to use an inline moisture trap and filter as air compressors will accumulate water and oil in the tank. I use an hvlp 4 stage turbine to dry my car but it's an expensive tool that we use at work, but is the same turbine set up as a master blaster. I have used a leaf blower in the past and as long as it is clean it seemed to work good.
If you can afford it, get a MB. It's just the right tool to have, period. It's the right tool for the job. For half the price you can get an AirForce Blaster. Still nice.
By Fox body in forum Auto Detailing 101
Last Post: 01-14-2018, 02:18 AM
By Bobbykart in forum Auto Detailing 101
Last Post: 12-04-2013, 10:03 PM
By c8n in forum Tricks, Tips and Techniques
Last Post: 05-14-2013, 10:16 AM
By oldgeek in forum Auto Detailing 101
Last Post: 01-15-2013, 11:47 AM
By supercharged in forum Off-Topic
Last Post: 07-30-2006, 12:24 PM
