Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    May 2013
    Dried up wax on plastic black trim
    When I detailed my car in March I taped up everywhere except the plastic black trim near the windshield. As a result I have small dried up wax spots all over it...didn't notice them until the next day. I was told by a sales rep at pep boys that windex or dawn would work. Tries Dawn and was unsuccessful. I also know there are products sold here specifically for this task but the results also appear to be mixed. I'd just like some advice from folks who have run into this issue and what they did to resolve it. Thanks for your help.
    Super Member zmcgovern45's Avatar
    Sep 2012
    St. Louis, MO
    3,443
    Re: Dried up wax on plastic black trim
    It really depends... I have had mixed luck removing wax from stained trim using various products. I like to think of it like doing laundry... some stains come out, others don't.
    I typically use diluted IPA (rubbing alcohol) on a cotton swab or microfiber towel to try to get the wax off of the trim. IPA is capable of stripping wax, therefore it works pretty well at cleaning wax off of trim too. Sometimes it will take a good amount of time and work to get it off though.
    If all else fails, hide it with a good trim restorer or vinyl dressing.
    Retired Professional Detailer
    Super Member erichaley's Avatar
    Apr 2013
    Lincoln, NE
    844
    Use some APC, start at a lower dilution ratio, say 10:1, and work up from there.
    2013 Honda Accord Touring - Crystal Black Pearl/Black
    Aug 2011
    90
    Both of the above are good. Use a toothbrush or other soft brush for extra cleaning. I use Megs APC+.
    Super Member greatwhitenorth's Avatar
    Jun 2013
    B.C.
    356
    I find if you hit it with a pressure washer some will come off then when you try to wipe it the spots don't spread around
    Super Member HateSwirls's Avatar
    Jun 2013
    3,632
    Get you some peanut butter, smooth, put a little on a terry cloth rag and work it in really well, sometime the oil in the peanut butter will break it up.
    Wipe it off to see if it removed it.
    Works at times.
    Super Member A-train's Avatar
    May 2011
    Upstate, SC
    1,167
    Try Tar X or Stoner Tarminator and a slightly stiff brush, spray, agitate and rinse. Repeat If necessary.
    Super Member dsg03gt's Avatar
    Jan 2013
    717
    I've always used a big pink eraser. It's always worked for me.
    Sent from my XT907 using Tapatalk 2
    Super Member Andr3wilson's Avatar
    May 2012
    Edmonton AB
    1,615
    Eraser pad such as a Magic Eraser (melamine foam) will do!
  10. #10
    Regular Member mleun481's Avatar
    Mar 2012
    Brooklyn, New York
    115
    Duragloss Wax Eraser worked for me
  1. Removing dried on wax from plastic trim
    By CSixDude in forum Ask your detailing questions!
    Last Post: 01-04-2021, 09:57 AM
  2. How to get dried compound off of black trim?
    By rob_v in forum Auto Detailing 101
    Last Post: 12-13-2015, 02:07 AM
  3. Dried up wax on black plastic and weather stripping
    By MichaelD16 in forum Auto Detailing 101
    Last Post: 12-03-2013, 03:19 PM
  4. Removing dried polish from plastic trim
    By mi77915 in forum Auto Detailing 101
    Last Post: 08-29-2012, 04:43 AM
  5. Will the Tornador Black remove dried wax from pebbled plastic?
    By courtsider in forum Auto Detailing 101
    Last Post: 04-10-2012, 08:57 AM
