» Detailing Classes
Results 11 to 20 of 30
    Sep 2011
    Maine
    135
    Re: Recommend products for swirl removal on 2008 Nighthawk Black Pearl Honda Civic using DA buffer?
    I'm used to DAT polishes and have been primarily using Menz PF2500/203S or SF4000 on Hondas. I recently started using SONAX Perfect Finish 4/6 and I think it may replace the Menz polishes for me on soft paints - more cut than SF4000/106FA but finishes just as well. I usually use Buff & Shine green or black pads.
    Friends who are more comfortable with SMAT polishes than I am get good results with Meguiars M205 on Hondas.
    I have also heard positive comments from people I trust about Scholl Concepts S20 Blue and Dodo Juice Supernatural Micro Prime on soft paints but I have not personally used these or seen the results. I just got some Micro Prime but haven't used it yet. I'm sure I'll buy S20 Blue when it is available in the USA as I like S3 Gold, S17+ and S40 from Scholl.
    Edit: Forgot the towels part - I've had the best luck with PakShak but the Korean towels from MicroFiberTech are also very good. I also can recommend the Autofiber Zero Edge towels and Zero Cuff wash mitt that MicrofiberTech sells (Auto Detailing Solutions also carries them). I hear very good things about Poorboys DMT towels but haven't used them. I'm sure the Microfiber Madness towels are excellent or CarPro US wouldn't be carrying them but they are definitely not cheap. I'm sort of a MF towel junky, although not as bad as Cooter, and these are what have liked best out of dozens of different towels.
    Member ksigna's Avatar
    Aug 2012
    56
    I recently worked on an Acura RL with soft paint. I did a 1 step with Duragloss 501 and a white pad with great results. I have also used Sonax Paint cleaner with a black LC flat pad with good results on a Lexus. I also add a little Optimum no rinse to my wash solution. Hope that helps.
    Kyle
  3. #13
    Aug 2012
    56
    I just want to add to my previous post. The AIO's I used didn't give the 100% correction you might be after but they made a huge difference with just using 1 step.
    Kyle
  4. #14
    Junior Member Sidecut's Avatar
    Jun 2013
    Thank you SanmerDetailing.
  5. #15
    Member
    Jan 2011
    48
    Check out this Nighthawk Black TL I did a while back.
    2010 Acura TL Nighthawk Black Pearl - Autopia Forums - Auto Detailing & Car Care Discussion Forum
    You can compare how bad your swirls are to the TL. If you only have light swirls, I would suggest something like m205 or HD polish and a tangerine polishing pad or white LC pad to get the job done.
    Edit- Forgot about the towels also. I used Pakshak silver surfers for all compound and polish removal. I then used MFT's blue 530 gsm towels for sealant removal.
  6. #16
    Senior Member dorkiedoode's Avatar
    Apr 2013
    Paradise
    307
    stay away from Orange Pad and UC. did my Black Accord and it left micro marring where you can only see in Sunlight. i kinda have a feeling that i was cutting too much but i wanted to get a few scratches out. so micro marring was left over the whole front hood. can be easily removed but shouldn't have been there if i used something less aggressive. be very gentle with this color and work your way up. test spot and patient.
    •Kevin
    UC - M205 - SF4500 - BFWD - BFMS
  7. #17
    Senior Member beamerstrumpet's Avatar
    Jun 2013
    1,031
    Gald I read this, I have a black fit. so ill be chiming in more myself with questions later.
  8. #18
    Senior Member zmcgovern45's Avatar
    Sep 2012
    St. Louis, MO
    3,443
    Retired Professional Detailer
  9. #19
    Senior Member c8n's Avatar
    Mar 2013
    40°56′45″N 74°14′42″W
    819
    Quote Originally Posted by J504 View Post
    I believe the 2010 TL is Crystal Black Pearl.
    I have 2012 CBP TL and just got the LC MF pads and would love to hear you thought on them on how they finished.
    2012 Acura CBP TL SH-AWD Tech
  10. #20
    Member
    Jan 2011
    48
    Quote Originally Posted by c8n View Post
    Thanks for the clarification. I will be doing a black 8th gen civic soon. I'll be sure to compare the difference between them. In regards to the MF pads, The LC left barely any haze,while the Meg's MF pads left a noticeable amount. But as a trade off, the MEgs cut a LOT faster than the LC pad. However, both should be followed up with a finishing polish anyways, which will easily clear up the haze from the Meg's pad.
  1. Swirl Removal And Paint Sealant Advice - Honda CR-V 2015 - Obsidian Blue Pearl
    By BlueHawk in forum Ask Mike Phillips your detailing questions!
    Last Post: 01-27-2016, 04:15 PM
  2. 2008 Black Honda Civic - Oxidation Removal
    By spinz in forum Show N' Shine
    Last Post: 01-04-2014, 01:27 PM
  3. 2008 Black Honda Civic Detail
    By csanto23 in forum Ask Mike Phillips your detailing questions!
    Last Post: 08-07-2013, 10:50 PM
  4. Black Nighthawk Pearl Civic
    By pampos in forum Show N' Shine
    Last Post: 04-15-2008, 01:45 PM
  5. Nighthawk Black Pearl Honda Pilot with PB PP & EXC
    By Couture in forum Show N' Shine
    Last Post: 06-20-2007, 05:38 AM
» September 2020
3031 1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 123
