Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    Apr 2012
    42
    Talking Some detailing questions
    Alright, somewhat new to detailing, however, I've waxed lots of cars in the past, and all done by hand. Now I'm looking at detailing my car, and this time I'm trying to get more equipped with a Porter Cable polisher and the required stuff. I've got some swirls that I'd like to remove on my car and parents car, so looking at getting the Porter Cable 7424XP 5.5" with some pads and everything needed.
    Here's my list of stuff that I have:
    1002 Collinite Liquid Insulator Wax (No. 845)
    1006 Collinite Liquid Sapphire Auto Wax #SS126 (16oz)
    5404 CarPro IronX (32oz)
    5444 CarPro TRIX Tar and Iron Remover
    Chemical Guys Black on BLACK SPRAY DRESSING
    Riccardo Blue Detailing Clay + Lubricant
    Here's what I'm looking to buy to complete my kit:
    Porter Cable 7424XP with 5" backing plate
    Orange polishing pad
    White polishing pad
    Black polishing pad
    Blue polishing pad
    Meguiars #105
    Meguiars #205
    I've heard good things about the Meguiars, so I'll probably be sticking to that, but what I want to know is; should I be using a sealant after the polish and before the Collinite 845 wax? If so, which sealant?
    I'll be doing these mostly on my car, which is white, but may do it on darker color cars, so need something that is good on all colors.
    Thanks,
    JP
    Apr 2012
    42
    Re: Some detailing questions
    I've read here on the forums that the Collinite 845 wax may be a sealant, if it is, can anyone suggest a good wax?
    I just want to make sure that I have all bases covered before I start my job, so looking at getting polish, sealant then wax, which ones?
    Thanks,
    JP
    Super Member zmcgovern45's Avatar
    Sep 2012
    St. Louis, MO
    3,443
    I would personally suggest ditching the M105 and going with the D300 and MF cutting pads.
    M105 can be a PITA to work with, D300 on the other hand is fantastic.
    I would also recommend getting 2-3 of each of the pads you had previously mentioned, as you will want to switch them out for a clean one while you are working every now and then.
    Sealant is not required if you are waxing, but if you are going to do both then you will apply sealant before the wax.
    845 is a very durable wax, so you would be fine simply using that, however there is nothing wrong with adding the extra protection of a sealant... there are tons of great ones to choose from. If you like Meguiar's check out M21 synthetic sealant.
    Retired Professional Detailer
    Apr 2012
    42
    Quote Originally Posted by zmcgovern45 View Post
    Thanks, I had in mind to get about 3pads of each. Also, is there anyway to prep a car for a complete detailing? As in remove any remaining wax residue before applying new polish/sealant/wax?
    I'll be washing, them IronX - TriX, then Claybar, then polish, sealant and then wax, is there any steps before to clean the car free of any leftover wax?
    As for sealant, I don't have any brand in mind, is there anything else good other than Mcguiars?
    Thanks,
    JP
    Super Member Evan.J's Avatar
    Sep 2012
    Pittsburgh, PA
    4,915
    I tried posting but had an issue anyway. I would go with the Griots garage da more powerful and a lifetime warranty
    I agree with the da microfiber correction kit and at the minimum of 2 of each pads to start
    Official Detailing Team Member of Air Force One
    Flex 3401 / Flex PE8 / Rupes 21 / G110v2 / GG6" / Rupes 75E / GG3"
    Click and Like my Facebook Page
    Apr 2012
    42
    Quote Originally Posted by Thoryamaha919 View Post
    Thanks, I'll look into it!
    Now, would like a bit more info on sealants and the preparation before detailing
    Sep 2012
    St. Louis, MO
    3,443
    Quote Originally Posted by jproy12 View Post
    Thanks,
    JP
    You can wash your car with a citrus based shampoo... ie Chemical Guys Citrus Wash to strip remaining wax/protection. These shampoos are very versatile in that they can be used for regular maintenance washing (when diluted properly) or for stripping your protection (when diluted to a stronger mixture of cleaner to water)... simply read the label on the product for the proper mixing ratios.
    I also pre-wash/soak with citrus wash in a foam gun (not foam lance) to help break down any existing LSP.
    **some people still use Dawn dish soap to strip LSP... it is effective, but not as preferred as a dedicated car washing shampoo**
    For sealant, I love Menzerna Power Lock... however, like most detailing supplies, you will find there are TONS of excellent sealants out there.
    Regarding the Meg's MF Correction Kit mentioned above... I would not get the "kit" and just get the cutting pads and D300, as I find the polishing pads and D301 are just not as good as a foam polishing pad and something like M205... just my opinion though.
    Also, you mentioned your car was white... but you never said what kind of car it is... mind sharing that info?
    Apr 2012
    42
    Thanks for the great info! Really appreciated.
    I drive a 2012 Subaru Forester, 5th Subaru, il try to post pics of my older cars.
    I'll look into a citrus based soap and some sealants, some great info in this thread that I'll keep handy when doing some research. I'll probably have more information to ask again, just a matter of time!
    Apr 2012
    42
    Alright, another questions; what is the ideal temperature to detail? The temperature these days in Canada are around 50-60deg F, is that warm enough?
    Alright, here are some pics of my current car:
    My last car, that I sold since I bought a house
  10. #10
    Super Member Vegas Transplant's Avatar
    Oct 2011
    Left Lane...Hammer Down
    4,446
    Thanks,
    JP
    845 is a great stand alone product.
    The last bottle that I ordered was a combo. Haven't found the need for the DP yet.Detailer’s Maximum Paint Protection Combo, best winter wax, best car wax winter protection
    Wish that I woulda remembered the ... White Flip Cap
    VT
    Quote Originally Posted by glen e View Post
  1. Several Detailing Questions :)
    By RocketGirl85 in forum Auto Detailing 101
    Last Post: 12-02-2019, 06:26 PM
  2. Questions on detailing my new car
    By 05RLS2 in forum Auto Detailing 101
    Last Post: 08-19-2014, 08:50 AM
  3. New here. detailing questions
    By cwienk in forum Auto Detailing 101
    Last Post: 05-20-2014, 01:40 PM
  4. detailing/OC questions
    By wallace03 in forum Auto Detailing 101
    Last Post: 06-24-2012, 02:54 AM
  5. Detailing questions...
    By KJW Detailing in forum Auto Detailing 101
    Last Post: 01-03-2008, 11:56 PM
