Do you guys tape off the edges and panels every time you wax/polish?
I have been, but its getting to be a chore, especially when you have to remove the tape and clean off the gunk that gets stuck in under the tape.....
Rotaries can burn the rubber trim but don't think that you have to tape with using the rotary only. Using the PC you still should tape. It depends on what products you are using. If you use products that stain plastic and don't tape, you'll have a nicely detailed car with white stains on the trim from dried up polish or wax which takes away from the overall appearance...
That being said... I don't tape . My solution to this is to use products that don't stain trim. Or you can dress all trim before polishing so that the polish will wipe off easier after you are done.
I would agree with budman3, I tape based on vehicle and how much plastic it has. Another reason I don't like vehicles with a bunch of plastic around them...any who. Taping is a bit of a pain but when you’re just starting to detail vehicles it's a good idea, once you get good at it you can probably do with out it but it doesn’t hurt to tape things off.
budman3, when you say you use products that don't stain which products are you referring to? Reason I ask is because I was under the impression that all polishing/compound products would leave that white residue? But you are correct dressing the trim works great.
