Engine Detailing - What to do when all purpose cleaner straight doesn't cut it?
Hey guys, I was doing an engine detail (not on my car) a little while ago and I was using optimum power clean straight to try to tackle some serious black grime on the metal under the hood. Some of it came out, but after 3 applications, more than 80% remained. And I was scrubbing it with a stiff brush!
What would be the next step to getting rid of that grime?
I was thinking about trying Wheel Brightener, but don't know if that would stain the metal, as I'm pretty sure it's not painted.
Maybe metal polish?
Re: Engine Detailing - What to do when all purpose cleaner straight doesn't cut it?
bump since this thread has reached page 2
Hard to say without seeing it. It seems you hit it with a strong enough cleaner if you're not diluting it, plus aggitating it with a brush. The only strong cleaner I've used in the past is Simple Green. You can check AG's list for other cleaners: Engine Cleaners & Degreasers,Clean engine,engine detailing products,engine degreaser,engine maintenance,how to clean engine,how to detail
I'd say if you can hit it with steam, that should do the trick, if it's that baked on after 3 applications + scrubbing.
Theres a product from Mothers called Billet Metal Polish. Its hard to find OTC, at least at my store. Anyhow, this stuff is pretty strong, at $17.99 for a small little tub, it cleans and polishes metal quite well. I dont think it would stain your metal (as long as its bare metal, not painted).
ive used simple green and zep purple with great success...just dont get the zep purple on the paint...
I am the heir to the primo spaghetti sauce fortune
Steam. Let full strength APC dwell, and then hit it with a steam cleaner.
2009 e90 BMW 335i - Montego Blue
Water based products are simply not the correct product for heavy levels of oils/greases etc. They can do the job, up to a point, but you are using pretty strong caustic products to achieve it and you risk un-necessary corrosion. With this sort of application I always recommend solvent based products. By having the solvent base you negate the need for nasty ingredients because the oil is soluble in the solvent itself and you do not rely on chemical reactions to make it all work. The only problem is that the products are basically 100% active and not dilutable - so they are more expensive.
Ok? So what product would you recommend?
try super degreaser from megs or grime reaper from CG
Last Post: 12-31-2016, 11:30 AM
Last Post: 06-07-2016, 12:20 PM
By AutoApollo in forum Auto Detailing 101
Last Post: 12-11-2015, 08:31 PM
By RWalleyTX in forum Auto Detailing 101
Last Post: 02-28-2015, 01:08 AM
By AustrianOak82 in forum Auto Detailing 101
Last Post: 11-03-2014, 11:03 AM
