Re: Speedy Prep Towel Torture Test
Excellent video, write up and I like the sound effects. I am glad you posted that because if I bought a speedy prep towel and it sounded like that I would have thrown it in the trash. Do you prefer clay or speedy prep towel now that you have used both?
I love my speedy prep towel. Makes claying soooo much faster. Even the fine grade does an amazing job of removing tough contaminants. Worth every penny.
Do you wash it out at the end of the whole car or after every panel? Can you use it with any clay lube?
Quite impressive!
The sound difference between the beginning and the end is remarkable.
Thanks for sharing.
haha...it sounds like corduroy pants!!
I am the heir to the primo spaghetti sauce fortune
It took a LOT of passes to get the paint "quiet". It also took a lot of rinsing out of the Speedy Prep.
Ultimately I went ahead and applied some more firm downward pressure to speed things up. I might not do that on good paint but on this car, a little marring would not make things worse. It's all eventually going to be followed by swirl removal anyway.
Italian Guy:
I definitely prefer the convenience of the speedy prep. There's just so much less that can go wrong and the technique is much simpler. Squirt, wipe, rinse, repeat, done. Clay is a big hassle.
Matt
Any clay lube works, I use ONR.I fold it into fours and use each square for an area about half the size of a car door. Then I switch to a clean side. After all four sides are used I rinse it in my wash bucket with just water and a grit guard. Then after the car is finished I rinse it in warm water for a while per instructions on the back of the towel package.
ill have to look into one of these towels..seriously.
i just about ruined my personal black truck with an elastrrofoam block...somehting has embedded under teh rubber and i cant find it...i had my ipod going when i "clayed" and didnt hear or see a thing until too late...
By smkdya in forum How to Videos
Last Post: 06-29-2016, 08:12 PM
By smkdya in forum Ask your detailing questions!
Last Post: 06-24-2016, 09:08 AM
By DRamsey in forum Product Reviews
Last Post: 03-05-2015, 09:25 PM
By Klasse Act in forum Off-Topic
Last Post: 05-23-2014, 04:58 AM
By brianch in forum Products Guides
Last Post: 04-10-2013, 10:00 AM
