» Detailing Classes
Page 76 of 77 FirstFirst ... 26666768697071727374757677 LastLast
Results 751 to 760 of 763
  1. #751
    Aug 2010
    Fairmont, MN
    3,101
    Re: Most regretted detailing product purchase
    OT: Why the double post?
    Bill
  2. #752
    Senior Member Jon TDS's Avatar
    Jul 2018
    133
    Quote Originally Posted by JFire72 View Post
    I would have to say C.Quart UK 3.0 is at the top of my list. Spent a full day prepping the paint so I could apply it. Spent 2 days on applying it because there is a wait period in between coatings. Then waited 3 more days for the initial cure process before applying Reload on it so I could finally drive. I don't know if I had a bad batch or what, but it rained less than 24 hours after I had pulled it out of the garage. And it already stopped its hydrophobic action. So I did a maintenance wash, and reapplied the Reload again. I had the same results as before.
    Unfortunately for me, I did it on my other vehicle too. Did same the process, and spent the same amount of time on it.
    One day I may try a better product, but for now, I'm spent on ceramic coatings.
    Sent from my SM-N950U using Tapatalk
    I thought Reload should be applied within 1 hour of cquk? No?
    Sent from my Mi A1 using Tapatalk
  3. #753
    Member mmhammer's Avatar
    Nov 2017
    Brooklyn MI
    66
    "If one molecule of that crap hits this truck, you're in for a really, really bad day".
    Hey, I think I like that line!
  4. #754
    Member JFire72's Avatar
    May 2018
    55
    Quote Originally Posted by Jon TDS View Post
    From what I had read it didn't matter when it was applied as long as it was after the 24 cure period of the last application. I don't know maybe I did it wrong. There were so many different answers on how to do it out there. Of course, if I was using this forum back then, my answer would have been more straightforward.
  5. #755
    Jul 2018
    133
    Yeah I haven't tried coating myself but from what I've gathered it should be applied within 1 hour window. But then again other people would have different methods too.
  6. #756
    Jul 2011
    Weaverville, Ca
    190
    I've posted this before, but I feel so ripped off that I feel the need to repost. CG Sprayable Leather is the worst. Shiny, squeaky, and slick. Complete crap.
  7. #757
    Senior Member RippyD's Avatar
    Jan 2016
    Portland, OR
    1,084
    Regarding Cquartz UK, my understanding is that it's an hour IF you want some protection as the coating is curing. For example, if you have to send a customer car home after applying and it might get wet. I believe if you can't get it at one hour it needs to be at least 24 hours. When I did some testing I had coatings fail when not giving them enough cure time before getting wet. Cure time is also temp and humidity dependent. Unless it's hot out it seems like 24 hour is the absolute minimum cure time before getting them wet.
    FYI, I had good results with Cquartz.
    2006 LR3 White // 2014 Boxster Agate Gray // 2012 Sentra Aspen White
    Sealant test resultsxxxxxDilution ratio chartxxxxxWheel cleaner info
  8. #758
    Senior Member The Guz's Avatar
    Jun 2013
    Lawndale, CA
    5,740
    You don't need to wait days in between additional coats. 45 min to 1 hour is what is recommended by CarPro. Also Reload can be applied 1 hour after the last coat of CQUK. It is recommended to wait at least 7 days before it gets wet or is washed. Reload is there to protect the coating in case it gets rained on sooner than later. I don't use Reload as it lacks the hydrophobics of Cquartz. But at the same time I am not too concerned with Rain as it does not rain here in Southern California.
    What was your prep?
    I have been enjoying CQUK 3.0 and and TiO2 and have been having very good results.
    Rippy got it correct.
    Quote Originally Posted by RippyD View Post
    Good point about coatings getting wet to soon.
  9. #759
    Jul 2017
    Casper, WY
    484
    Guz serious question, 3.0 with gliss or the Ti02...which one di you prefer and why
    Sent from my SM-G930V using Tapatalk
  10. #760
    Senior Member swanicyouth's Avatar
    Mar 2011
    Limerick, PA
    9,330
    Quote Originally Posted by minerigger View Post
    It doesn't do anything. I applied it 2 consecutive days to ensure even coverage and it had over 24hrs to cure. Then the rain started and it had zero sheeting or beading properties. I have crazy amount of water spots and dirt seemed to stick worse....basically everything opposite of what I've heard, seen, read on the product
    Ah; I know - it must be contaminated - try Reset! Or... user error - 24 hrs? Maybe thatís when yr supposed FINISH applying the 2nd coat. If you START at 24 hrs - the whole thing is toast. Thatís your problem.
    What happens is - the nano bridges are too bi-polar to crosslink with the carrier solution which supports the retarding of the curing process. So, unless itís topped with Reload v. 2.4a^4 - youíll be left with water behavior that just doesnít want to behave.
    Of course, your paint is protected. You just need to apply Hydro2 to bring back the beading in each water spot... But, before you do that - clean up the coating with Echo, followed by Eraser, and a good Iron X snow foam. Be aware -using infrared heating lamps during this process may prematurely catalyze the SiO2 in the coating - in effect - making the whole process redundant...So, make sure the humidity is 76-78.5% if youíre using UK v.3. If not, youíll need our newest version CQ Dubai v2.7 - which was specially formulated to harden in an ozone depleted environment on Lamborghini paint.
    What polish did you use? You can only use Essence. Or, Essence +, or Super Essence +++. Or Ultimate Essence #1 +. One of those. I canít recall. Iíd email CarPro. They can clarify this ASAP. Your simply not following directions. Not the directions on the bottle (theyíre BS) - but the uber super secret directions that are only mentioned by a guy on a forum via a post I can no longer find. Mods deleted it because it mentioned a brand of special coating towel they donít sell.
    Seriously though... regretful purchase - Master Blaster. A lot of redundant traditional soaps gathering dust. Griots Rubber Cleaner - wasnít even worth it at BOGO. Megís Super Degreaser - couldnít clean the oil off a salad bowl.
  11. Thanks PurpleTowel thanked for this post
    Likes MattPersman, Eldorado2k, PurpleTowel liked this post
  1. Non regretful detailing product purchase
    By VISITOR in forum Auto Detailing 101
    Last Post: 12-26-2018, 09:03 PM
  2. RECAP Most Regretted Detailing Product Purchases
    By allenk4 in forum Products Guides
    Last Post: 11-26-2015, 01:43 PM
  3. First Time Product Purchase
    By RJS5689 in forum Auto Detailing 101
    Last Post: 08-01-2013, 01:26 PM
  4. New Product purchase
    By 94LT1 in forum Off-Topic
    Last Post: 06-15-2008, 05:11 PM
  5. POLL : Which new product is your next purchase ??
    By ScottB in forum New Car Care Products
    Last Post: 04-27-2007, 09:55 PM
Members who have read this thread: 312
» January 2019
3031 1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31 12
