Results 11 to 20 of 27
    Super Member Flash Gordon's Avatar
    Feb 2010
    Memphis, TN ~ USA 1
    10,450
    Re: Getting bugs out of clear bra?
    Try using a heat gun. Hold the gun about 4" away from the area you're working on
    Regular Member Morphiusrt's Avatar
    May 2012
    Brockton
    107
    Quote Originally Posted by Morphiusrt View Post
    I know rubbing alcohol is safe on paint but is like sandpaper to a clear bra so just be careful. Make sure to test a spot out of sight.
    If you can find out the brand then you can contact the manufacturer and they will be more then willing to help you. My problem is mine came from a third party installer who uses different brands and they went out of business
    I don't know why I had 2 bashing smileys not bashing you at all. I want to bash myself sometimes trying to clean this thing lol. I have thought of removing it a few times already.
    "You miss 100% of the shots you don't take" -Wayne Gretzky
    http://www.facebook.com/BayStateDetailing
  3. #13
    Super Member loudog2's Avatar
    Aug 2008
    St. Charles, IL.
    2,880
    I use stoners with the pressure washer and it usually does fine. Alcohol softens the bra which can help loosen, just be careful not to rub hard. Alcohol is a last case senerio.
  4. #14
    Newbie Member LuvMyM2's Avatar
    Mar 2019
    I just tried the Hydrogen Peroxide method on my car- the results were immediate and appear to be fantastic. It's been overcast here for the past couple of days so I can't see if the surface of the ppm is impacted by the HP, but boy does it eat bugs off of it! I used HP on a q-tip, then gently applied over affected areas. Not the fastest method but it removed every single bug splatter. Thank you, thank you, thank you!
  5. Thanks BudgetPlan1 thanked for this post
  6. #15
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by LuvMyM2 View Post
    I’ve had phenomenal success getting
    embedded bugs out of Paint Protection
    Film using XPEL’s Film Cleaner, or
    PF1’s Film Cleanse. Of course: YMMV.
  7. #16
    Jun 2013
    Montreal, Quebec
    3,996
    I have never seen that problem before but my one though was to use a microfiber cutting disk with a light polish or a cleaner wax... Any solvents on clearbra are bad ;(
  8. #17
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by Calendyr View Post
    When did light polishes or cleaner
    waxes stop containing solvents?
  9. #18
    Jun 2013
    Montreal, Quebec
    3,996
    Are you really comparing a wax to a pure solvent like Alcohol or Acetone?
  10. #19
    Dec 2010
    Ohio, USA
    21,057
    Of course not.
    You implied that polishes and cleaner waxes
    don’t contain solvents; and you’d be wrong.
  11. #20
    Jun 2013
    Montreal, Quebec
    3,996
    Of course not.
    I have never seen any ill effect on clearbra from waxes or polishes. On the other hand, a little overspray from alcohol or body prep and you have to polish the clearbra out to remove the damage. Learned that one the hard way ;(
  1. Bugs Bugs Bugs
    By 01AUDI in forum Auto Detailing 101
    Last Post: 12-08-2017, 08:42 AM
  2. Bugs Bugs Bugs
    By cleanfreak3 in forum Ask your detailing questions!
    Last Post: 04-13-2015, 10:09 PM
  3. There are bugs... and then, there are LOVE BUGS
    By courtdale in forum Auto Detailing 101
    Last Post: 09-15-2011, 09:28 PM
  4. bugs
    By rifle in forum Auto Detailing 101
    Last Post: 06-18-2009, 05:06 PM
  5. Bugs
    By jfsully in forum Auto Detailing 101
    Last Post: 02-11-2007, 09:46 AM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
